HA CPU temps
Hi guys,
So I’m running my home assistant in a dedicated server (Ubuntu server 18.04), and I’m trying to make the CPU temps showing on HA.
I searched on the web but only found how to do it in RPi.
Spent all day trying, but no luck.
Can some one help me?
Paulo aka Fidel
Look at the glances component
website for glances, has install instructions
https://nicolargo.github.io/glances/
Or netdata.
Netdata sounds promising. If not I’ll check glances.
Thank you
Are you running Hassio did you install in a virtual environment?
If the latter you can run a command line sensor and pull the data that way.
That’s what I was trying. Can you explain how to do it?
Are you running it on RaspberryPi?
That only work with RaspberryPi.
use this:
- platform: command_line
  name: CPU Temperature
  command: "cat /sys/class/thermal/thermal_zone0/temp"
  unit_of_measurement: "°C"
  value_template: '{{ value | multiply(0.001) | round(1) }}'
I am running on a NUC with debian and it works perfectly
EDIT: Sorry, @silvrr, I didn’t see you posted the same thing.
Thanks for this! I needed F and couldn’t figure out how to output it with the command so I adjusted the template to:
value_template: '{{ (((value * 0.001) * 9/5) + 32) | round(0) }}'
I will try, but pretty sure it won’t do.
When I do: cat /sys/class/thermal/thermal_zone0/temp at the command line nothing happen.
How did you install?
Again if on a non Hassio install try:
cat /sys/class/thermal/thermal_zone*/temp
When I got home I’ll try.
This is what I got:
paulo@paulo_server:~$ cat /sys/class/thermal/thermal_zone*/temp
cat: '/sys/class/thermal/thermal_zone*/temp': No such file or directory
This is the only way to get only the CPU temp Value, nothing else. That I found.
root@paulo_server:/home/paulo#  /usr/bin/sensors | grep "CPU Temperature" | cut -c18-28
    +35.0°
Finaly done.
Here is the code if someone need:
    command: "sensors | grep 'CPU Temperature' | awk '{ print $3 }'"
    value_template: '{{ value | multiply(0.1) | round(1) }}'
Thanks to anyone that spent some time to help me.
$ cat /sys/devices/virtual/thermal/thermal_zone?/temp
will list the contents of the temp files in all the thermal zones.
I’m running on a virtual machine Ubuntu 18.10 , tried without success, did you install anything on Ubuntu?
trying to show temps on hassio
If running Hassio on a NUC, what is the proper way to get CPU temp? Using the Hassio command line or the host?
try this:
paste <(cat /sys/class/thermal/thermal_zone*/type) <(cat /sys/class/thermal/thermal_zone*/temp) | column -s $'\t' -t | sed 's/\(.\)..$/.\1°C/'
then this:
  command: "cat /sys/class/thermal/thermal_zone2/temp"
  value_template: "{{ value | multiply(0.001) | round(2) }}"
The command gives the following result:
cat: /sys/class/thermal/thermal_zone2/temp: No data available
acpitz 27.8°C
acpitz 29.8°C
iwlwifi 52.0°C
x86_pkg_t.e°C
