Last week power loss killed my HA running on Virtualbox. It seems to boot but web gui isn’t coming up. ALL network aspects have been vetted - it is there. Observer responds on http and reports OK. On console, I looked at core and supervisor. Core implies container is not running. I tried running supervisor repair and then core again but does not help. Here is supervisor log.
worst case, is there a way to get a backup and install on a new one or anyone think this is recoverable? My SAMBA shares ARE accessible and there is a snapshot from last week before this happened. Thanks
Start by copying those, to another disk ;), while your “there”
remove FTP-ADDON
uncommend ALL automations/scripts/bullock and devices etc, that you have in configuration.yaml … try reboot again (REBOOT not restart)
Thanks,
tried that - hardly anything in my configuration.yaml file to begin with. not doing too much. I did find this on reboot in home-assistant.log - next post. was having issues getting formatted in this post.
2023-03-07 15:47:49.409 ERROR (SyncWorker_0) [homeassistant.util.json] Could not parse JSON content: /config/.storage/core.config_entries
File "/usr/src/homeassistant/homeassistant/util/json.py", line 39, in load_json
return orjson.loads(fdesc.read()) # type: ignore[no-any-return]
orjson.JSONDecodeError: unexpected character: line 1 column 1 (char 0)
2023-03-07 15:47:49.410 ERROR (MainThread) [root] Uncaught exception
File "/usr/local/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 226, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 214, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 128, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 646, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/runner.py", line 109, in setup_and_run_hass
hass = await bootstrap.async_setup_hass(runtime_config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 151, in async_setup_hass
await async_from_config_dict(config_dict, hass) is not None
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 259, in async_from_config_dict
await hass.config_entries.async_initialize()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1098, in async_initialize
config = await storage.async_migrator(
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 44, in async_migrator
if (store_data := await store.async_load()) is not None:
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 117, in async_load
return await self._load_task
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 126, in _async_load
return await self._async_load_data()
File "/usr/src/homeassistant/homeassistant/helpers/storage.py", line 144, in _async_load_data
data = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/util/json.py", line 45, in load_json
raise HomeAssistantError(error) from error
homeassistant.exceptions.HomeAssistantError: unexpected character: line 1 column 1 (char 0)
hmmm, yeah i tend to agree with your initial statement
if core.config_entries is corrupt you are better of installing a new HA, and hope you can use your backup, thou as you have access to Samba share, you can copy all your Views, automations etc.etc.
thanks. luckily sometime ago i setup the backup to google drive. installed new, restored backup and i am good.
