HA crashed after update
After updating to the new latest version of Core and Supervisor I’ve lost any control over HA. Can’t even reboot it remotely. Unfortunately, it installed in a remote location and I don’t have a physical access to it.
Maybe you can suggest something.
[547548727616] [Errno 5] I/O error: '/usr/src/homeassistant/homeassistant/helpers/check_config/__init__.py'
5:17:20 PM – (ERROR) Home Assistant WebSocket API - message first occurred at 4:57:42 PM and shows up 5 times
Failed to to call /supervisor/stats -
5:17:16 PM – (ERROR) Home Assistant Supervisor - message first occurred at 4:57:33 PM and shows up 36 times
Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed ('172.30.32.2', 80)]
5:17:16 PM – (ERROR) Home Assistant Supervisor - message first occurred at 4:57:33 PM and shows up 84 times
[Errno 5] I/O error: '/usr/local/lib/python3.11/site-packages/hass_frontend/frontend_latest/93163-nJX9YYByYYQ.js'
5:17:10 PM – (ERROR) components/http/static.py - message first occurred at 4:56:15 PM and shows up 38 times
[547548727616] Error handling message: [Errno 5] I/O error: '/config/.storage/hacs.critical' (unknown_error) XX from XX.XX.XXX.XXX (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36)
5:17:10 PM – (ERROR) Home Assistant WebSocket API - message first occurred at 4:56:06 PM and shows up 8 times
JSON file reading failed: /config/.storage/hacs.critical
5:17:10 PM – (ERROR) util/json.py - message first occurred at 4:56:06 PM and shows up 8 times
[547486856384] Error handling message: Unknown error (unknown_error) XX from XXX.XXX.XXX.XXX (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/118.0.0.0 Safari/537.36)
5:16:21 PM – (ERROR) Home Assistant WebSocket API - message first occurred at 4:56:21 PM and shows up 6 times
Error while processing event StatisticsTask(start=datetime.datetime(2023, 10, 30, 15, 55, tzinfo=datetime.timezone.utc), fire_events=True): The database connection has not been established
5:05:16 PM – (ERROR) Home Assistant Supervisor - message first occurred at 4:56:19 PM and shows up 14 times
Unhandled exception
5:04:17 PM – (ERROR) /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py - message first occurred at 5:03:02 PM and shows up 2 times
Error doing job: Task exception was never retrieved
5:00:56 PM – (ERROR) HACS (custom integration)
/usr/local/lib/python3.11/asyncio/base_events.py:1923: RuntimeWarning: coroutine 'async_check_can_reach_url' was never awaited
5:00:56 PM – (WARNING) runner.py
Error fetching info
5:00:51 PM – (ERROR) System Health
Unhandled exception
4:59:21 PM – (ERROR) /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py - message first occurred at 4:58:51 PM and shows up 2 times
