HA crashes when I edit or create automations
I have used HA for several years and I have about 45 devices primary for optimimising power consumption and heating of my home. The system is fully automatic and keeps indoor climate stable all year around to minimal cost. Works fine! But now suddenly I can’t edit nor create automations.
When I in Settings > Animations pick an existing Animation the Animation editor in Lovlace starts OK. When I try to add new “Condition” the list of alternatives shows up OK. But when I select “entities” from the list the editor crashes and pop me out from the Animation editor. HELP!
I am running HA version 20260107.0 on a RPi4.
It’s not crashing but for some users in some browsers it seems like the dialog is causing a spurious browser.back action, which takes you back to the automations page.
This issue has already been reported, you can downgrade back to 2025.12 temporarily if this is a showstopper for you until it gets resolved.
Thank you! I will downgrade.
Do I need to load the backup from the upgrade from 2025.12?
Jag körde Lovlace via Chrome under W11 när det bråkade. Testar just nu att använda Edge. Ser ut att fungera !!! Testar mer imorgon.
OOps Wrong language…
I used Lovelace from Chrome on a PC running W11. But now I tested using Edge instead. Seems to work fine!!! Will test more tomorrow.
I’m experiencing this exact thing. Can you link to the report/bug issue so I can follow? I rolled back and all is well.
Edit: Found it on github.
