HA crashing on the reg, conbee II error & Hue issue
I’m running:
Home Assistant 2022.10.4
Supervisor 2022.10.0
Operating System 9.2
Frontend 20221010.0 - latest
on a Raspberry Pi 4 on a Kingston A400 SSD with a ConBee II
I upgraded from an SD to an SSD because HA killed my SD card. As part of this I did a fresh install of HA - since then it’s been crashing every 2-3 days and I have to power it off and on again to get it back.
I don’t have any community mods or addons installed (although I needed to add the file browser to get at Logs1). I’m baffled as to what could be causing it. There’s also an Processing: home-assistant.log.1…
issue with my Conbee II (I tried a new stick in case that was the problem but the issue persists)
I’ve had a look for solutions but got lost quickly. The final line of Logs1 suggests I should disable availability reporting for a Hue Light that I have but I can’t work out how to do that.
Conbee II logs:
2022-10-19 23:58:00.652 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 1 of 3)
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 172, in async_initialize
2022-10-19 23:58:04.061 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 2 of 3)
2022-10-19 23:58:07.458 WARNING (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator (attempt 3 of 3)
2022-10-19 23:58:07.461 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ConBee II for zha
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 112, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 185, in async_initialize
Sample of Logs1:
2022-10-18 17:56:24.831 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.10/site-packages/zigpy/topology.py", line 52, in scan_loop
    await self.scan()
  File "/usr/local/lib/python3.10/site-packages/zigpy/topology.py", line 63, in scan
    await self._scan_task
  File "/usr/local/lib/python3.10/site-packages/zigpy/topology.py", line 86, in _scan
    await device.neighbors.scan()
  File "/usr/local/lib/python3.10/site-packages/zigpy/neighbor.py", line 96, in scan
    return await self._scan()
  File "/usr/local/lib/python3.10/site-packages/zigpy/neighbor.py", line 107, in _scan
    status, rsp = await self._device.zdo.Mgmt_Lqi_req(idx, tries=3, delay=1)
  File "/usr/local/lib/python3.10/site-packages/zigpy/util.py", line 131, in retry
    r = await func()
  File "/usr/local/lib/python3.10/site-packages/zigpy/device.py", line 297, in request
    await self._application.request(
  File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 654, in request
    await self.send_packet(
  File "/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py", line 398, in send_packet
    await self._api.aps_data_request(
AttributeError: 'NoneType' object has no attribute 'aps_data_request'
2022-10-18 17:56:30.007 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
    await self.scan()
    r = await func()
2022-10-18 18:20:08.826 ERROR (MainThread) [homeassistant] Error doing job: Task was destroyed but it is pending!
2022-10-18 18:20:08.835 ERROR (MainThread) [homeassistant] Error doing job: Task was destroyed but it is pending!
2022-10-18 18:20:08.837 ERROR (MainThread) [homeassistant] Error doing job: Task was destroyed but it is pending!
2022-10-18 18:20:08.839 ERROR (MainThread) [homeassistant] Error doing job: Task was destroyed but it is pending!
2022-10-19 00:15:45.848 WARNING (MainThread) [homeassistant.components.hue.bridge.light] Device Extended color light 2 changed state while reported as disconnected. This might be an indicator that routing is not working for this device or the device is having connectivity issues. You can disable availability reporting for this device in the Hue options. Device details: _TZ3210_hzy4rjz3 - Extended color light (TS0505B) fw: 0.0.4
