HA Custom Integration to control BLE ADV Ceiling Fans / Lamps
Hello Community !
I created a new HA Custom Integration in order to control Ceiling Fans / Lamps using Bluetooth Low Energy Advertising, it is available here.
It allows to control directly from HA the Fans / Lamps that are controlled by one of the following Android Phone Apps:
  • FanLamp Pro
  • Zhi Jia
  • LampSmart Pro
  • Lamp Smart Pro - Soft Lighting / Smart Lighting
  • Zhi Guang
  • ApplianceSmart
  • Vmax smart
  • Zhi Mei Deng Kong
  • Smart Light
This HA custom integration is the equivalent of the ESPHome custom components already available and discussed in this topic, but directly in HA using the Bluetooth stack of the host and with discovery and configuration by UI directly.
I would need some BETA testers to help in bug discovery and feedback so if you are eligible based on requirements, and have a Fan / Lamp controlled by one of the given apps, please give it a try!
Do not hesitate to open feature requests or bugs!
Hi @NicoIIT, I will beta test this later today and let you know.
I still have some problems with my ESP32 “range” so this hopefully can be a great option!
Hi @NicoIIT, I just quickly tested it and it’s really good.
I just found what I think it’s a bug: I manually add the configuration because I knew the parameters (but I also try the “duplicate config”) and when I add the name of the device and select the type of the main light it keeps asking me to configure at least one fan or light as per the picture below.
Of course the config is done from my side and I can’t progress in any way. I tried to move some parameters to see if it allows me to proceed but it never did.
Just to confirm the lights blinked as asked in the setup so everything should work.
thanks again for this
@Bonfo10 : fixed in Release 0.9.2! Copy / Paste issue: the finalization was blocked if no Fan was added whereas it should block only if no Fan nor Light is added.
I got a new FanLamp Pro controlled ceiling fan light (https://aliexpress.com/item/1005008133433827.html) and found your integration. I tried to beta test, but without success. :wink:
I tried “duplicate config” with the paired app. The integration detects the keypress and finds three configurations. But none of those lets the lamp blink, so the setup fails.
Any suggestions?
Are you sure the device is in pairing mode? For my fan I have to kill power and it’s only able to be paired in the first 5s. I would toggle power for each controller to restart pairing mode on your device
Yes! I now tried both: Pairing mode and discovery mode. Both with and without disconnecting the lamp from power before the pairing and / or each configuration attempt.
I’ll take one of my ESPs lying around to make sure it’s generally working and not a problem with the lamp. If that works, I’ll try again with the new integration.
Hello @narolinus, I see 3 possibilities:
  1. Your phone app is not paired with your device (yes, this is a possibility, so I need to be sure :slight_smile: ). Be sure the phone App effectively controls your device, and that you are not using the “Master Control” part (does not exists in Fan Lamp Pro).
  2. Your phone is near your HA host so the Bluetooth of the HA host can listen the Bluetooth of the phone, but the lamp is too far from the HA host and then the Bluetooth of the HA host cannot reach the lamp to control it
  3. There is a bug! As the app is in beta, this is likely to occur… If you can I would need you to:
  • Launch “btmon” shell command (need sudo) on your host, this will start the monitoring of the bluetooth commands issued / received by your bluetooth card
  • Retry the same ‘Duplicate Config’ procedure
  • Stop the “btmon” command and copy the whole output into a new issue.
@Maxcodesthings: the “Duplicate Config” does not require pairing, it is an interactive procedure that is listening to the commands issued by another already paired controller in order to reproduce them: That’s one of the main interest of this new component :slight_smile:
Thanks a lot for this testing!
  1. Yes it is and it does.
  2. I doubt it, but it may be possible. I just have one of those little usb-thumb-sticks for bluetooth, but the phone, the lamp and the stick are almost equally 2m away from each other in a triangle.
  3. I will try this, when I am back at home in the evening.
Thank you!
Just played around with btmon… but apart from an extremely fast log stream (I must have a few too many bluetooth devices) there’s not much to see here. In particular, the logged messages show no obvious relation to the lamp. On the other hand, an extremely large number of messages from smartphones, Shellys etc.
I suspect that it’s less to do with the integration and more to do with my setup.
As a test, I have set up an ESP32 with ESPHome and the components for it. The control works without any problems. Entering the parameters in the integration does not lead to any success. On the contrary, it hangs when testing the configuration.
For testing purposes, I am now setting up a fresh test environment on a Home Assistant Yellow.
Yes this is normal, the base of the protocol of those lamps is to only emit commands using BLE Advertising (as UDP broadcast would do in network): there is no established connection with the lamps.
I also think it could be the issue: the stack I am using (directly use the Bluetooth HCI socket) may be incompatible with an intensive use of the bluetooth card by other ways (bluez / dbus / …). I am thinking of using the mgmt-api, this may solve some of the potential incompatibilities.
This one has to be fixed, if you could give me the parameters you used I will fix this!
Thanks for your tests, and sorry it does not work for you :sweat:
Good news first: I set up a test environment with a Home Assistant Yellow (15.0) and the integration works like a charm even with the yellow being 15m and a concrete wall away.
Nice work! Anything works out of the box with cloning the paired app.
I am still not shure where it fails in my main setup (that replaced the yellow earlier this year). But that seems to be a very specific failure of MY setup only.
So, thanks for your help! I am still trying to figure this out, but I will not bother you, unless I find a hint towards a solution. :wink:
P.S.: The “hanging” parameters where fanlamp_pro_v3 (0x26935E80 / 1), which worked great on the ESP.
Interestingly they did not work with the Setup on the Yellow, there the working params where fanlamp_pro_v2 (0x26935E80 / 1).
I retried those on the main HA, but that did not work, either.
This is weird. I retried the latter on the main HA and the lamp did blink and I was able to successfully add the device to HA!
But it still does not work. Instead it just displays “connection lost” in a popup a while after using any of the controls.
Now I am quite sure it has to do with utilization / number of Bluetooth devices / quality of the Bluetooth stick.
Is it possible to get this to work with BLE proxy?
Hello @ignacio82 : this is in the plans, have a look to the enhancement list and give it a :+1:
Hello @narolinus, First of all I really appreciate your various tests and the time you spend on this testing!
For the fanlam_pro_v2 vs fanlamp_pro_v3, the only difference between the 2 is that a supplementary key is generated (using python “pycryptodome” package) and added to the command sent. Most of the devices supporting the v2 are also supporting the v3 as they are just ignoring this supplementary key.
The problem is then probably linked to the “pycryptodome” pacakge. May I ask you to check in the HA logs the exception you (probably) have? And also the version of HA core and the version of pycroptodome installed with command:
pip freeze | grep pycryptodome
Thanks again!
Quick check before leaving for work: The command shows pycryptodome is not installed on the HAOS host, i guess it is installed a container than… have to check later.
There are not many errors logged or warnings logged. In CORE:
Logger: habluetooth.scanner
Source: runner.py:154
Firstime seen: 2025-03-24 at 06:06:35 (10 Events)
Lasttime seen: 2025-03-24 at 21:22:23
hci0 (8C:88:2B:53:CD:22): Bluetooth scanner has gone quiet for 111.03942108154297s, restarting
hci0 (8C:88:2B:53:CD:22): Bluetooth scanner has gone quiet for 93.77119445800781s, restarting
hci0 (8C:88:2B:53:CD:22): Bluetooth scanner has gone quiet for 98.95101165771484s, restarting
hci0 (8C:88:2B:53:CD:22): Bluetooth scanner has gone quiet for 117.13240051269531s, restarting
hci0 (8C:88:2B:53:CD:22): Bluetooth scanner has gone quiet for 97.90149688720703s, restarting
In Host:
2025-03-24 21:14:15.906 ha kernel: Bluetooth: hci0: Opcode 0x2041 failed: -16
2025-03-24 21:14:15.915 ha kernel: Bluetooth: hci0: Opcode 0x2041 failed: -16
2025-03-24 21:22:23.036 ha kernel: Bluetooth: hci0: Opcode 0x2041 failed: -16
2025-03-24 21:22:23.071 ha kernel: Bluetooth: hci0: Opcode 0x2041 failed: -16
(Some more of the same, always around the time of my tests.)
Cryptodome @ homeassistant container:
pycryptodome==3.22.0
pycryptodomex==3.22.0
I got a new Bluetooth Stick for my HA-Main-Host and of course that was the problem… Now anything is working absolutely smooth. Sorry for wasting your time. :wink:
I think the fact that I got many Bluetooth-Proxies (Shellies and ESPHome) in my setup covered the problem as most of the other devices use those proxies.
:laughing: That’s very good news because the less I could say is that the migration to mgmt-api is just impossible, details in the related issue.
