HA Dashboard Icons
How could I move the icons up a little bit in the widget? They show up low.
They are currently set at absolute positions that don’t resize well, I am aiming to make them proportional at some point to help with this.
Thanks. That would be great. Also is there a way to remove the side bars on a iframe? I make the frame larger and they just keep getting larger too.
This is fixed in the next beta for images like that - there is an image argument you use instead of the URL argument and the dash will size the image to the widget
Nice :slight_smile:
Was it this weekend you were saying the next beta was coming out?
Hopefully yes.
hi,
Is there a way to disable the - / + controls of light widget?
Yes you could try using a switch widget instead.
@aimc hm… but how? I mean, how to force a light entity to be seen as a switch? In this specific case it’s hue lights.
like this:
anyname:
  widget_type: switch
  title: any title
  entity: light.anylight
@ReneTode, Thanks!!! it worked.
