I have been using a Teclast p80x (8 inch tablet) for a permanent HA dashboard. in the home. Been using it for about 2.5 years.
Now I have a swollen battery because it was plugged in 100% of the time. (I have since read threads around putting in a power plug to cycle charging)
I have been able to convert the tablet to run without a battery, using a capacitor and a diode, and still using the standard power USB C port on the tablet. i.e. no extra external cables.
Battery in the tablet had 5 wires connected to the circuit board, 2 power (red), 2 ground (black) , and 1 data? (white) - (not sure this is relevant - but added for completeness)
I removed the battery, but left the battery control module (had to remove a bunch of tape, and cut spot welds to battery tabs.)
Plugged in tablet with USB A to USB C cable
Couldn’t use a USB C to USB C - something special about these and the power management on the tablet main board. I could only ever find up to 0.1 volts anywhere on the board
Use a voltage meter to find 5 volts on the tablet main board
Connect wire from tablet main board 5 volts via diode (i had a spare 1N4007 available) to the +ve battery terminal on the battery control module (diode points toward battery control module - didn’t want capacitor pushing any voltage back to tablet main board and diode usually rips out about 0.8 volts, so battery control module will only get about 4.2volts. i.e. same as orig battery)
Put ceramic (104) 0.1uF capacitor across +ve and -ve battery terminals on the battery control module
This worked - Using the normal tablet USB C charging port (with USB A to USB C cable)
Tablet booted.
Could log in, change settings etc.
Battery percentage shows 100% - Doesn’t show its charging. (Doesn’t bother me)
However, as soon as I tried to run Home Assistant Companion app, that I expect drew too much peak current, the tablet would act if the (imaginary) battery had been disconnected and the power cable had been pulled out. I.e. back to pre boot up stage. i.e. it was off - not in standby.
So I upped the capacitor size - only one I had available was a 400v 10uF Aluminium Electrolytic.
Now it seems to be working no issues at all. Been running for about 16 hours as of this post.
Problem I have is the 400v 10uF cap is way too big to fit inside the tablet case, hence not able to mount back on the wall with my current mount.
So need to ponder how do I determine the correct size capacitor?
Ceramic 104 (0.2 uF) was too small.
Electrolytic 10uF 400V is too big.
As 10uF is working, I am going to try and use a Tantalum 10uF 25V cap.
It’s small enough form factor to fit inside the back case of the tablet (5mm by 3mm)
I was able to pick up a a few 10uF Tantalums today.
I have substituted the 10uF 400v Electrolytic for a single 10uF 35V ($1.15 AUD) Tantalum.
Tested it - Seems to be working ace.
Soldered it all together and added heat shrink, and put the rear case back on.
It’s working and back on the wall!
No case mods required.
No extra power supply required.
No battery.
It was going to cost me about $20 AUD for a battery (delivered - and not until March…) - and might only get another 2 years out of it.
Sorted, piecing togther a few youtube videos and a few forums, for a little time and about $3 AUD worth of parts.
Love the internet!!!
If any of this has helped, pop a reply in down below.
I will post some pics next.
Fantastic work bud. The way I approached this issue after one tablet blowing on me.
I have the charger for the tablet plugged into a zigbee plug, the tablet is loaded Home Assistant so it’s sensors are exposed including battery level.
Then I have wall panel loaded as the main launcher to lock it down.
Then I have automations set up within Home assistant to monitor the battery level, when it drops below 5% the automation turns on the plug, then when the battery level hits 99% another automation turns off the plug.
Well. All seemed to be going well.
However, the tablet is now switching itself off randomly. (About once a day).
Also every now and then the wifi disconnects. Requires me to turn off wifi, then turn it back on again.
So my Frankenstein fix is not so good.
Anyone have any idea why the tablet might be doing this?
I had that with an older samsung, turns out that running a dashboard overheats the processor and it shuts off. Perhaps try to see where the SOC is on the board and add a huge lump of copper? If I made my dashboard more simple, mine would stop shutting off.
Another idea is to just have home assistant check to see if the tablet is online and if it isn’t, toggle the power to the tablet to get it to turn back on?
Yep. Exactly the same problem with all three of my Samsung x200’s. Wish I had never bought them…Good luck with finding a solution. Apparently, it is one of Samsung’s “better ideas”…
did you try it without the battery terminal? I have an old Google Nexus 10 and directly connected a 5dcv power supply to the battery pins with a 16v 4700uF capacitor in the middle of it.
I am thinking about replacing this old tablet with something cheap…like a Teclast from Alixexpress…
When you say “diode points toward battery control module” do you mean the diode cathode (the end with the white stripe) is connected to the control module? Normal voltage drop across silicon diodes is 0.7v and 0.4v for germanium diodes. Of course the 1N4000 series are silicon.
You located a 5v source on the motherboard which originated from your USB charger, then connected that 5v source via your diode, never a bad idea to isolate, to the charge controller. It seems that the 10uf capacitor is working for you but there are small socalled super capacitors using solid state devices which can operate above 5v and have values up to half a farad (500,000uf) if you wanted to ensure longer non powered operation.
