I have searched and can’t figure out how to resolve my issue.
My HA does not work and all my devices are greyed out.
I get the notification:
Invalid config
The following integrations and platforms could not be set up:
default_config
Please check your config and logs.
Based on my searches this is a malformed or corrupted DB. I have used the file editor to delete the “home-assistant_v2.db” file. This should allow HA to rebuild the file. Then I restarted the HA. No change. Still get the error.
I am running HA (Hassio) on a VM. I have SSH & web terminal setup.
How can I resolve my issue? Is there something else I am missing?
Maybe I need to stop the core? If so then how do I delete the file?
I have a backup of HA for the VM. I restored to a backup from a month ago.
Encountered same issue. The DB file was very large. I deleted it and restarted.
Same issue. Here are the errors.
Apparently there was an issue with the supervisor.
I logged in via SSH and used command “hassio ha update”. This gave me the most current update of the Supervisor. Everything worked once it was complete.
