HAOS on Rpi-4
- Core 2024.5.0
- Supervisor 2024.04.4
- Operating System 12.2
- Frontend 20240501.0
HA started with openweathermap not loading but looking into the HA logs, it seems the problem is not integration specific. Log pasted below. Seems like HA is looking for python in 3.12 while installed is 3.11:
python --version
Python 3.11.8
Logger: homeassistant.setup
Source: setup.py:322
First occurred: 9:30:43 PM (1 occurrences)
Last logged: 9:30:43 PM
Setup failed for 'openweathermap': Unable to import component: cannot import name 'resource_filename' from 'pkg_resources' (/usr/local/lib/python3.12/site-packages/pkg_resources/__init__.py)
File "/usr/src/homeassistant/homeassistant/loader.py", line 976, in async_get_component
comp = await self.hass.async_add_import_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/loader.py", line 1036, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 144, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 995, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/openweathermap/__init__.py", line 8, in <module>
from pyowm import OWM
File "/usr/local/lib/python3.12/site-packages/pyowm/__init__.py", line 4, in <module>
from pyowm.owm import OWM
File "/usr/local/lib/python3.12/site-packages/pyowm/owm.py", line 14, in <module>
from pyowm.commons import cityidregistry
File "/usr/local/lib/python3.12/site-packages/pyowm/commons/cityidregistry.py", line 5, in <module>
from pkg_resources import resource_filename
ImportError: cannot import name 'resource_filename' from 'pkg_resources' (/usr/local/lib/python3.12/site-packages/pkg_resources/__init__.py)
File "/usr/src/homeassistant/homeassistant/setup.py", line 322, in _async_setup_component
component = await integration.async_get_component()
File "/usr/src/homeassistant/homeassistant/loader.py", line 996, in async_get_component
self._component_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 988, in async_get_component
comp = self._get_component()
