HA_Desktop_Companion
[20220825T142242]-API -> {"data":[{"unique_id":"currently_active_window","type":"sensor","state":"HA_Desktop_Companion - Share your Projects! - Home Assistant Community och 12 sidor till - Arbete – Microsoft? Edge","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.754157777777777,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":true,"icon":"mdi:microphone"},{"unique_id":"free_ram","type":"sensor","state":666988,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"54","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T142242]-API CODE <- OK
[20220825T142242]-API <- "{\"currently_active_window\": {\"success\": true}, \"uptime\": {\"success\": true}, \"camera_in_use\": {\"success\": true}, \"microphone_in_use\": {\"success\": true}, \"free_ram\": {\"success\": true}, \"cpu_usage\": {\"success\": true}}"
It vas sucesfully send to api
camera_in_use - False==False-SAME ! mean it was send in previous step and walue did not changed so it is skiping the information so save speed and space on packet
But it was not false in the previous step.
Here I tried it again:
Removed some lines that was not relevant to make it more compact
[20220825T143431]-MAIN-Syncer Tick n:83
# is false and previously false?
[20220825T143431]-API DATA SKIP -> camera_in_use - False==False-SAME !
[20220825T143431]-API DATA SKIP -> microphone_in_use - False==False-SAME !
[20220825T143431]-API DATA SKIP -> location_in_use - False==False-SAME !
[20220825T143433]-API -> {"data":[{"unique_id":"currently_active_window","type":"sensor","state":"Möte | Microsoft Teams","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.95170138888889,"icon":"mdi:timer-outline"},{"unique_id":"free_ram","type":"sensor","state":567476,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"91","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T143433]-API CODE <- OK
[20220825T143433]-API <- "{\"currently_active_window\": {\"success\": true}, \"uptime\": {\"success\": true}, \"free_ram\": {\"success\": true}, \"cpu_usage\": {\"success\": true}}"
[20220825T143441]-MAIN-Syncer Tick n:84
# is true
[20220825T143441]-API DATA -> camera_in_use - True
[20220825T143441]-API DATA -> microphone_in_use - True
[20220825T143442]-API -> {"data":[{"unique_id":"free_ram","type":"sensor","state":528636,"icon":"mdi:clock"},{"unique_id":"currently_active_window","type":"sensor","state":"Möte | Microsoft Teams","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.95444,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":true,"icon":"mdi:microphone"},{"unique_id":"cpu_usage","type":"sensor","state":"46","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T143443]-API CODE <- OK
[20220825T143443]-API <- "{\"free_ram\": {\"success\": true}, \"currently_active_window\": {\"success\": true}, \"uptime\": {\"success\": true}, \"camera_in_use\": {\"success\": true}, \"microphone_in_use\": {\"success\": true}, \"cpu_usage\": {\"success\": true}}"
[20220825T143451]-MAIN-Syncer Tick n:85
# still true
[20220825T143451]-API DATA -> camera_in_use - True
[20220825T143451]-API DATA -> microphone_in_use - True
[20220825T143452]-API -> {"data":[{"unique_id":"free_ram","type":"sensor","state":605060,"icon":"mdi:clock"},{"unique_id":"currently_active_window","type":"sensor","state":"Registereditorn","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.957191666666667,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":true,"icon":"mdi:microphone"},{"unique_id":"cpu_usage","type":"sensor","state":"19","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T143453]-API CODE <- OK
[20220825T143453]-API <- "{\"free_ram\": {\"success\": true}, \"currently_active_window\": {\"success\": true}, \"uptime\": {\"success\": true}, \"camera_in_use\": {\"success\": true}, \"microphone_in_use\": {\"success\": true}, \"cpu_usage\": {\"success\": true}}"
[20220825T143501]-MAIN-Syncer Tick n:86
[20220825T143501]-API DATA -> camera_in_use - True
[20220825T143501]-API DATA -> microphone_in_use - True
[20220825T143503]-API -> {"data":[{"unique_id":"free_ram","type":"sensor","state":488660,"icon":"mdi:clock"},{"unique_id":"currently_active_window","type":"sensor","state":"HA_Desktop_Companion - Share your Projects! - Home Assistant Community och 12 sidor till - Arbete – Microsoft? Edge","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.959986944444445,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":true,"icon":"mdi:microphone"},{"unique_id":"cpu_usage","type":"sensor","state":"32","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T143503]-API CODE <- OK
[20220825T143503]-API <- "{\"free_ram\": {\"success\": true}, \"currently_active_window\": {\"success\": true}, \"uptime\": {\"success\": true}, \"camera_in_use\": {\"success\": true}, \"microphone_in_use\": {\"success\": true}, \"cpu_usage\": {\"success\": true}}"
[20220825T143511]-MAIN-Syncer Tick n:87
# now is false, and previously false (incorrect, it was true)
[20220825T143511]-API DATA SKIP -> camera_in_use - False==False-SAME !
[20220825T143511]-API DATA SKIP -> microphone_in_use - False==False-SAME !
[20220825T143512]-API -> {"data":[{"unique_id":"free_ram","type":"sensor","state":527020,"icon":"mdi:clock"},{"unique_id":"currently_active_window","type":"sensor","state":"Registereditorn","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.962751666666666,"icon":"mdi:timer-outline"},{"unique_id":"cpu_usage","type":"sensor","state":"66","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T143513]-API CODE <- OK
[20220825T143513]-API <- "{\"free_ram\": {\"success\": true}, \"currently_active_window\": {\"success\": true}, \"uptime\": {\"success\": true}, \"cpu_usage\": {\"success\": true}}"
[20220825T143521]-MAIN-Syncer Tick n:88
[20220825T143521]-API DATA SKIP -> camera_in_use - False==False-SAME !
[20220825T143521]-API DATA SKIP -> microphone_in_use - False==False-SAME !
[20220825T143522]-API DATA -> cpu_usage - 59
[20220825T143522]-API -> {"data":[{"unique_id":"free_ram","type":"sensor","state":712296,"icon":"mdi:clock"},{"unique_id":"currently_active_window","type":"sensor","state":"Registereditorn","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":22.96548611111111,"icon":"mdi:timer-outline"},
Or do I misinterpret the log?
Los is async so it means not all messages go in right order some task can be finished before others and wise versa, i plan to rewrite data aggregation before sending :slight_smile: hopefulli i will manage to do t it today :slight_smile:
Tested it again and it is working
I tested the smash all the bugs on our own computer and it’s stable and the logs say it sends the data but nothing is received in HA.
[20220825T161701]-MAIN ->LOADED Start
[20220825T161701]-MAIN ->Setting Loaded
[20220825T161701]-MAIN ->UI Set
[20220825T161701]-MAIN-configuration.yaml LOADED
[20220825T161701]-MAIN-Sync Timer Registered
[20220825T161701]-MAIN ->LOADED Done
[20220825T161725]-MAIN-Registration Clicked
[20220825T161725]-MAIN-URL:
[20220825T161725]-API -> connection Verified:True
[20220825T161725]-MAIN-URL-STATUS:Validated
[20220825T161731]-{"device_id":"desktop-bg2pnvn_debug","app_id":"ha_desktop_companion","app_name":"HA_Desktop_Companion","app_version":"0.0.1.0","device_name":"DESKTOP-BG2PNVN_DEBUG","manufacturer":"Acer","model":"Nitro AN515-52","os_name":"Microsoft Windows 10 Home","os_version":"Microsoft Windows NT 10.0.19043.0","supports_encryption":false,"app_data":{"push_websocket_channel":true}}
[20220825T161731]-API -> {"device_id":"desktop-bg2pnvn_debug","app_id":"ha_desktop_companion","app_name":"HA_Desktop_Companion","app_version":"0.0.1.0","device_name":"DESKTOP-BG2PNVN_DEBUG","manufacturer":"Acer","model":"Nitro AN515-52","os_name":"Microsoft Windows 10 Home","os_version":"Microsoft Windows NT 10.0.19043.0","supports_encryption":false,"app_data":{"push_websocket_channel":true}}
[20220825T161732]-MAIN-Device Registere in API
[20220825T161732]-MAIN -> Entity Registration
[20220825T161733]-API -> {"data":{"unique_id":"battery_level","name":"Battery Level","type":"sensor","state":"","device_class":"battery","unit_of_measurement":"%","entity_category":"diagnostic","icon":"mdi:battery"},"type":"register_sensor"}
[20220825T161733]-API CODE <- Created
[20220825T161733]-API <- "{\"success\": true}"
[20220825T161733]-{"success":true}
[20220825T161733]-API = battery_level - Sensor Sucesfully Registered
[20220825T161734]-API -> {"data":{"unique_id":"battery_state","name":"Battery State","type":"sensor","state":"","device_class":"battery","entity_category":"diagnostic","icon":"mdi:battery-minus"},"type":"register_sensor"}
[20220825T161734]-API CODE <- Created
[20220825T161734]-API <- "{\"success\": true}"
[20220825T161734]-{"success":true}
[20220825T161734]-API = battery_state - Sensor Sucesfully Registered
[20220825T161736]-API -> {"data":{"unique_id":"cpu_temp","name":"CPU Temperature","type":"sensor","state":"","unit_of_measurement":"°C","entity_category":"diagnostic","icon":"mdi:cpu-64-bit"},"type":"register_sensor"}
[20220825T161737]-API CODE <- Created
[20220825T161737]-API <- "{\"success\": true}"
[20220825T161737]-{"success":true}
[20220825T161737]-API = cpu_temp - Sensor Sucesfully Registered
[20220825T161738]-API -> {"data":{"unique_id":"free_ram","name":"Free Ram","type":"sensor","state":"","unit_of_measurement":"kilobytes","entity_category":"diagnostic","icon":"mdi:clock"},"type":"register_sensor"}
[20220825T161738]-API CODE <- Created
[20220825T161738]-API <- "{\"success\": true}"
[20220825T161738]-{"success":true}
[20220825T161738]-API = free_ram - Sensor Sucesfully Registered
[20220825T161739]-API -> {"data":{"unique_id":"cpu_usage","name":"CPU Usage","type":"sensor","state":"","unit_of_measurement":"%","entity_category":"diagnostic","icon":"mdi:cpu-64-bit"},"type":"register_sensor"}
[20220825T161740]-API CODE <- Created
[20220825T161740]-API <- "{\"success\": true}"
[20220825T161740]-{"success":true}
[20220825T161740]-API = cpu_usage - Sensor Sucesfully Registered
[20220825T161741]-API -> {"data":{"unique_id":"wifi_state","name":"Wifi State","type":"sensor","state":"","icon":"mdi:wifi"},"type":"register_sensor"}
[20220825T161741]-API CODE <- Created
[20220825T161741]-API <- "{\"success\": true}"
[20220825T161741]-{"success":true}
[20220825T161741]-API = wifi_state - Sensor Sucesfully Registered
[20220825T161742]-API -> {"data":{"unique_id":"wifi_ssid","name":"Wifi SSID","type":"sensor","state":"","icon":"mdi:wifi"},"type":"register_sensor"}
[20220825T161742]-API CODE <- Created
[20220825T161742]-API <- "{\"success\": true}"
[20220825T161742]-{"success":true}
[20220825T161742]-API = wifi_ssid - Sensor Sucesfully Registered
[20220825T161743]-API -> {"data":{"unique_id":"currently_active_window","name":"Currently Active Window","type":"sensor","state":"","icon":"mdi:application"},"type":"register_sensor"}
[20220825T161744]-API CODE <- Created
[20220825T161744]-API <- "{\"success\": true}"
[20220825T161744]-{"success":true}
[20220825T161744]-API = currently_active_window - Sensor Sucesfully Registered
[20220825T161745]-API -> {"data":{"unique_id":"uptime","name":"Uptime","type":"sensor","state":"","unit_of_measurement":"h","entity_category":"diagnostic","icon":"mdi:timer-outline"},"type":"register_sensor"}
[20220825T161745]-API CODE <- Created
[20220825T161745]-API <- "{\"success\": true}"
[20220825T161745]-{"success":true}
[20220825T161745]-API = uptime - Sensor Sucesfully Registered
[20220825T161746]-API -> {"data":{"unique_id":"camera_in_use","name":"Camera in use","type":"binary_sensor","state":false,"icon":"mdi:camera"},"type":"register_sensor"}
[20220825T161746]-API CODE <- Created
[20220825T161746]-API <- "{\"success\": true}"
[20220825T161746]-{"success":true}
[20220825T161746]-API = camera_in_use - Sensor Sucesfully Registered
[20220825T161748]-API -> {"data":{"unique_id":"microphone_in_use","name":"Microphone in use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},"type":"register_sensor"}
[20220825T161748]-API CODE <- Created
[20220825T161748]-API <- "{\"success\": true}"
[20220825T161748]-{"success":true}
[20220825T161748]-API = microphone_in_use - Sensor Sucesfully Registered
[20220825T161749]-API -> {"data":{"unique_id":"location_in_use","name":"Location in use","type":"binary_sensor","state":false,"icon":"mdi:crosshairs-gps"},"type":"register_sensor"}
[20220825T161749]-API CODE <- Created
[20220825T161749]-API <- "{\"success\": true}"
[20220825T161749]-{"success":true}
[20220825T161749]-API = location_in_use - Sensor Sucesfully Registered
[20220825T161750]-API -> {"data":{"unique_id":"is_charging","name":"Is Charging","type":"binary_sensor","state":false,"device_class":"plug","icon":"mdi:power-plug-off"},"type":"register_sensor"}
[20220825T161751]-API CODE <- Created
[20220825T161751]-API <- "{\"success\": true}"
[20220825T161751]-{"success":true}
[20220825T161751]-API = is_charging - Sensor Sucesfully Registered
[20220825T161751]-MAIN-App registered in REG
[20220825T161801]-MAIN-Syncer Tick n:0
[20220825T161801]-API DATA -> camera_in_use - Falsealse true}"
[202208
[20220825T161801]-API DATA -> currently_active_window - Settings – Home Assistant - Google Chrome
[20220825T161801]-API DATA -> uptime - 3719,4082419444444
[20220825T161801]-API DATA -> wifi_state -
[20220825T161801]-API DATA -> wifi_ssid -
[20220825T161801]-API DATA -> battery_level - 77
[20220825T161801]-API DATA -> battery_state - On AC
[20220825T161801]-API DATA -> free_ram - 944552
[20220825T161801]-API DATA -> is_charging - False
[20220825T161802]-API DATA -> cpu_usage - 46
[20220825T161811]-MAIN-Syncer Tick n:0
[20220825T161811]-API DATA -> uptime - 3719,411019722222
[20220825T161811]-API DATA -> location_in_use - True
[20220825T161811]-API DATA -> currently_active_window - HA_Desktop_Compaino
[20220825T161811]-API DATA -> camera_in_use - False
[20220825T161811]-API DATA -> microphone_in_use - False
[20220825T161811]-API DATA -> wifi_ssid -
[20220825T161811]-API DATA -> battery_state - On AC
[20220825T161811]-API DATA -> battery_level - 77
[20220825T161811]-API DATA -> free_ram - 899840
[20220825T161812]-API DATA -> is_charging - False
[20220825T161812]-API DATA -> wifi_state -
[20220825T161812]-API DATA -> cpu_usage - 56
[20220825T161821]-MAIN-Syncer Tick n:0
[20220825T161821]-API DATA -> uptime - 3719,4137975
[20220825T161821]-API DATA -> currently_active_window - Ny mapp
[20220825T161821]-API DATA -> location_in_use - True
[20220825T161821]-API DATA -> camera_in_use - False
[20220825T161821]-API DATA -> microphone_in_use - False
[20220825T161821]-API DATA -> wifi_ssid -
[20220825T161821]-API DATA -> wifi_state -
[20220825T161821]-API DATA -> battery_level - 77
[20220825T161821]-API DATA -> is_charging - False
[20220825T161821]-API DATA -> battery_state - On AC
[20220825T161821]-API DATA -> free_ram - 626544
[20220825T161822]-API DATA -> cpu_usage - 32
[20220825T161831]-MAIN-Syncer Tick n:0
[20220825T161831]-API DATA -> uptime - 3719,4165752777776
[20220825T161831]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T161831]-API DATA -> location_in_use - True
[20220825T161831]-API DATA -> camera_in_use - False
[20220825T161831]-API DATA -> microphone_in_use - False
[20220825T161831]-API DATA -> wifi_state -
[20220825T161831]-API DATA -> wifi_ssid -
[20220825T161831]-API DATA -> battery_level - 76
[20220825T161831]-API DATA -> battery_state - On AC
[20220825T161831]-API DATA -> is_charging - False
[20220825T161831]-API DATA -> free_ram - 578180
[20220825T161832]-API DATA -> cpu_usage - 17
[20220825T161841]-MAIN-Syncer Tick n:0
[20220825T161841]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T161841]-API DATA -> uptime - 3719,4193530555553
[20220825T161841]-API DATA -> camera_in_use - False
[20220825T161841]-API DATA -> microphone_in_use - False
[20220825T161841]-API DATA -> location_in_use - True
[20220825T161841]-API DATA -> is_charging - False
[20220825T161841]-API DATA -> free_ram - 587628
[20220825T161841]-API DATA -> wifi_state -
[20220825T161841]-API DATA -> wifi_ssid -
[20220825T161841]-API DATA -> battery_state - On AC
[20220825T161841]-API DATA -> battery_level - 76
[20220825T161842]-API DATA -> cpu_usage - 9
[20220825T161851]-MAIN-Syncer Tick n:0
[20220825T161851]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T161851]-API DATA -> uptime - 3719,4221308333335
[20220825T161851]-API DATA -> camera_in_use - False
[20220825T161851]-API DATA -> microphone_in_use - False
[20220825T161851]-API DATA -> location_in_use - True
[20220825T161851]-API DATA -> battery_level - 76
[20220825T161851]-API DATA -> battery_state - On AC
[20220825T161851]-API DATA -> wifi_ssid -
[20220825T161851]-API DATA -> is_charging - False
[20220825T161851]-API DATA -> wifi_state -
[20220825T161851]-API DATA -> free_ram - 601528
[20220825T161852]-API DATA -> cpu_usage - 50
Will try one of the other versions.
that is not possible since [20220825T161748]-{“success”:true} that mean HA recieved the message
Can you send me a screenshot of device from HA
try to delete everything from HA and from local and start again many users contacted me with error this solveed the issues most of the time
@Hellis81 can you please or someone test the latest build if it is finally stable ?
Notifications should also fork now
Update steps:
  1. Delete all previous files
  2. extract nev files
  3. delete existing device fro HA
  4. Start new version (fill token and url in if not loaded)
  5. Click register wait few minutes check if values reported in HA are correct
Little bit of Visual tweaking
I got this in the newest version on my personal computer (admin rights):
[20220825T193919]-MAIN ->LOADED Start
[20220825T193919]-MAIN ->Setting Loaded
[20220825T193919]-MAIN ->UI Set
[20220825T193919]-MAIN-configuration.yaml LOADED
[20220825T193919]-MAIN-Sync Timer Registered
[20220825T193919]-MAIN ->LOADED Done
[20220825T193932]-MAIN-Registration Clicked
[20220825T193932]-MAIN-URL:
[20220825T193932]-API -> connection Verified:True
[20220825T193932]-MAIN-URL-STATUS:Validated
[20220825T193937]-API -> {"device_id":"desktop-bg2pnvn_debug","app_id":"ha_desktop_companion","app_name":"HA_Desktop_Companion","app_version":"0.0.1.0","device_name":"DESKTOP-BG2PNVN_DEBUG","manufacturer":"Acer","model":"Nitro AN515-52","os_name":"Microsoft Windows 10 Home","os_version":"Microsoft Windows NT 10.0.19043.0","supports_encryption":false,"app_data":{"push_websocket_channel":true}}
[20220825T193938]-API CODE <- Created
[20220825T193938]-API <- "{\"cloudhook_url\":\"\",\"remote_ui_url\":\"\",\"secret\":null,\"webhook_id\":\"\"}"
[20220825T193938]-{"cloudhook_url":"","remote_ui_url":"","secret":null,"webhook_id":""}
[20220825T193938]-MAIN-Device Registere in API
[20220825T193938]-MAIN-Valid Settings Saved
[20220825T193938]-MAIN -> Entity Registration
[20220825T193939]-API -> {"data":{"unique_id":"battery_level","name":"Battery Level","type":"sensor","state":"","device_class":"battery","unit_of_measurement":"%","entity_category":"diagnostic","icon":"mdi:battery"},"type":"register_sensor"}
[20220825T193939]-API CODE <- Created
[20220825T193939]-API <- "{\"success\": true}"
[20220825T193939]-{"success":true}
[20220825T193939]-API = battery_level - Sensor Sucesfully Registered
[20220825T193940]-API -> {"data":{"unique_id":"battery_state","name":"Battery State","type":"sensor","state":"","device_class":"battery","entity_category":"diagnostic","icon":"mdi:battery-minus"},"type":"register_sensor"}
[20220825T193941]-API CODE <- Created
[20220825T193941]-API <- "{\"success\": true}"
[20220825T193941]-{"success":true}
[20220825T193941]-API = battery_state - Sensor Sucesfully Registered
[20220825T193942]-API -> {"data":{"unique_id":"cpu_temp","name":"CPU Temperature","type":"sensor","state":"","unit_of_measurement":"°C","entity_category":"diagnostic","icon":"mdi:cpu-64-bit"},"type":"register_sensor"}
[20220825T193942]-API CODE <- Created
[20220825T193942]-API <- "{\"success\": true}"
[20220825T193942]-{"success":true}
[20220825T193942]-API = cpu_temp - Sensor Sucesfully Registered
[20220825T193943]-API -> {"data":{"unique_id":"free_ram","name":"Free Ram","type":"sensor","state":"","unit_of_measurement":"kilobytes","entity_category":"diagnostic","icon":"mdi:clock"},"type":"register_sensor"}
[20220825T193943]-API CODE <- Created
[20220825T193943]-API <- "{\"success\": true}"
[20220825T193943]-{"success":true}
[20220825T193943]-API = free_ram - Sensor Sucesfully Registered
[20220825T193945]-API -> {"data":{"unique_id":"cpu_usage","name":"CPU Usage","type":"sensor","state":"","unit_of_measurement":"%","entity_category":"diagnostic","icon":"mdi:cpu-64-bit"},"type":"register_sensor"}
[20220825T193945]-API CODE <- Created
[20220825T193945]-API <- "{\"success\": true}"
[20220825T193945]-{"success":true}
[20220825T193945]-API = cpu_usage - Sensor Sucesfully Registered
[20220825T193946]-API -> {"data":{"unique_id":"wifi_state","name":"Wifi State","type":"sensor","state":"","icon":"mdi:wifi"},"type":"register_sensor"}
[20220825T193946]-API CODE <- Created
[20220825T193946]-API <- "{\"success\": true}"
[20220825T193946]-{"success":true}
[20220825T193946]-API = wifi_state - Sensor Sucesfully Registered
[20220825T193947]-API -> {"data":{"unique_id":"wifi_ssid","name":"Wifi SSID","type":"sensor","state":"","icon":"mdi:wifi"},"type":"register_sensor"}
[20220825T193948]-API CODE <- Created
[20220825T193948]-API <- "{\"success\": true}"
[20220825T193948]-{"success":true}
[20220825T193948]-API = wifi_ssid - Sensor Sucesfully Registered
[20220825T193949]-API -> {"data":{"unique_id":"currently_active_window","name":"Currently Active Window","type":"sensor","state":"","icon":"mdi:application"},"type":"register_sensor"}
[20220825T193949]-API CODE <- Created
[20220825T193949]-API <- "{\"success\": true}"
[20220825T193949]-{"success":true}
[20220825T193949]-API = currently_active_window - Sensor Sucesfully Registered
[20220825T193950]-API -> {"data":{"unique_id":"uptime","name":"Uptime","type":"sensor","state":"","unit_of_measurement":"h","entity_category":"diagnostic","icon":"mdi:timer-outline"},"type":"register_sensor"}
[20220825T193950]-API CODE <- Created
[20220825T193950]-API <- "{\"success\": true}"
[20220825T193950]-{"success":true}
[20220825T193950]-API = uptime - Sensor Sucesfully Registered
[20220825T193952]-API -> {"data":{"unique_id":"camera_in_use","name":"Camera in use","type":"binary_sensor","state":false,"icon":"mdi:camera"},"type":"register_sensor"}
[20220825T193952]-API CODE <- Created
[20220825T193952]-API <- "{\"success\": true}"
[20220825T193952]-{"success":true}
[20220825T193952]-API = camera_in_use - Sensor Sucesfully Registered
[20220825T193953]-API -> {"data":{"unique_id":"microphone_in_use","name":"Microphone in use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},"type":"register_sensor"}
[20220825T193953]-API CODE <- Created
[20220825T193953]-API <- "{\"success\": true}"
[20220825T193953]-{"success":true}
[20220825T193953]-API = microphone_in_use - Sensor Sucesfully Registered
[20220825T193954]-API -> {"data":{"unique_id":"location_in_use","name":"Location in use","type":"binary_sensor","state":false,"icon":"mdi:crosshairs-gps"},"type":"register_sensor"}
[20220825T193955]-API CODE <- Created
[20220825T193955]-API <- "{\"success\": true}"
[20220825T193955]-{"success":true}
[20220825T193955]-API = location_in_use - Sensor Sucesfully Registered
[20220825T193956]-API -> {"data":{"unique_id":"is_charging","name":"Is Charging","type":"binary_sensor","state":false,"device_class":"plug","icon":"mdi:power-plug-off"},"type":"register_sensor"}
[20220825T193956]-API CODE <- Created
[20220825T193956]-API <- "{\"success\": true}"
[20220825T193956]-{"success":true}
[20220825T193956]-API = is_charging - Sensor Sucesfully Registered
[20220825T193956]-MAIN-App registered in REG
[20220825T194006]-MAIN-Syncer Tick n:0
[20220825T194006]-API DATA -> camera_in_use - Truedow - Settings – Home Assistant - Google Chrome}
[20220825T194006]-API DATA -> microphone_in_use - False
[20220825T194006]-API DATA -> location_in_use - True
[20220825T194006]-API DATA -> wifi_state -
[20220825T194006]-API DATA -> battery_state - On AC
[20220825T194006]-API DATA -> battery_level - 25
[20220825T194006]-API DATA -> wifi_ssid -
[20220825T194006]-API DATA -> free_ram - 964968
[20220825T194007]-API DATA -> is_charging - False
[20220825T194007]-API DATA -> cpu_usage - 35
[20220825T194016]-MAIN-Syncer Tick n:0
[20220825T194016]-API DATA -> currently_active_window - Settings – Home Assistant - Google Chrome
[20220825T194016]-API DATA -> camera_in_use - True
[20220825T194016]-API DATA -> uptime - 3723
[20220825T194016]-API DATA -> location_in_use - True
[20220825T194016]-API DATA -> microphone_in_use - False
[20220825T194016]-API DATA -> wifi_ssid -
[20220825T194016]-API DATA -> wifi_state -
[20220825T194016]-API DATA -> free_ram - 925932
[20220825T194016]-API DATA -> is_charging - True
[20220825T194016]-API DATA -> battery_level - 25
[20220825T194016]-API DATA -> battery_state - Fully Charged
[20220825T194017]-API DATA -> cpu_usage - 34
[20220825T194026]-MAIN-Syncer Tick n:0
[20220825T194026]-API DATA -> currently_active_window -
[20220825T194026]-API DATA -> uptime - 3723
[20220825T194026]-API DATA -> location_in_use - True
[20220825T194026]-API DATA -> camera_in_use - True
[20220825T194026]-API DATA -> microphone_in_use - False
[20220825T194026]-API DATA -> wifi_state -
[20220825T194026]-API DATA -> battery_state - Fully Charged
[20220825T194026]-API DATA -> battery_level - 25
[20220825T194026]-API DATA -> wifi_ssid -
[20220825T194026]-API DATA -> free_ram - 866424
[20220825T194026]-API DATA -> is_charging - True
[20220825T194027]-API DATA -> cpu_usage - 14
[20220825T194036]-MAIN-Syncer Tick n:0
[20220825T194036]-API DATA -> uptime - 3723
[20220825T194036]-API DATA -> currently_active_window - Settings – Home Assistant - Google Chrome
[20220825T194036]-API DATA -> camera_in_use - True
[20220825T194036]-API DATA -> location_in_use - True
[20220825T194036]-API DATA -> microphone_in_use - False
[20220825T194037]-API DATA -> wifi_state -
[20220825T194037]-API DATA -> wifi_ssid -
[20220825T194037]-API DATA -> battery_level - 25
[20220825T194037]-API DATA -> battery_state - Fully Charged
[20220825T194037]-API DATA -> is_charging - True
[20220825T194037]-API DATA -> free_ram - 824124
[20220825T194038]-API DATA -> cpu_usage - 51
[20220825T194046]-MAIN-Syncer Tick n:0
[20220825T194046]-API DATA -> uptime - 3723
[20220825T194046]-API DATA -> currently_active_window - Settings – Home Assistant - Google Chrome
[20220825T194046]-API DATA -> camera_in_use - True
[20220825T194046]-API DATA -> location_in_use - True
[20220825T194046]-API DATA -> microphone_in_use - False
[20220825T194047]-API DATA -> is_charging - True
[20220825T194047]-API DATA -> battery_state - Fully Charged
[20220825T194047]-API DATA -> wifi_ssid -
[20220825T194047]-API DATA -> battery_level - 26
[20220825T194047]-API DATA -> free_ram - 839964
[20220825T194047]-API DATA -> wifi_state -
[20220825T194048]-API DATA -> cpu_usage - 19
[20220825T194056]-MAIN-Syncer Tick n:0
[20220825T194056]-API DATA -> currently_active_window -
[20220825T194056]-API DATA -> uptime - 3723
[20220825T194056]-API DATA -> camera_in_use - False
[20220825T194056]-API DATA -> microphone_in_use - False
[20220825T194056]-API DATA -> location_in_use - True
[20220825T194056]-API DATA -> battery_level - 26
[20220825T194056]-API DATA -> battery_state - Fully Charged
[20220825T194057]-API DATA -> wifi_state -
[20220825T194057]-API DATA -> wifi_ssid -
[20220825T194057]-API DATA -> is_charging - True
[20220825T194057]-API DATA -> free_ram - 906092
[20220825T194058]-API DATA -> cpu_usage - 23
[20220825T194106]-MAIN-Syncer Tick n:0
[20220825T194107]-API DATA -> battery_level - 26
[20220825T194107]-API DATA -> currently_active_window -
[20220825T194107]-API DATA -> uptime - 3723
[20220825T194107]-API DATA -> camera_in_use - False
[20220825T194107]-API DATA -> microphone_in_use - False
[20220825T194107]-API DATA -> location_in_use - True
[20220825T194107]-API DATA -> wifi_state -
[20220825T194107]-API DATA -> wifi_ssid -
[20220825T194107]-API DATA -> battery_state - Fully Charged
[20220825T194107]-API DATA -> free_ram - 910956
[20220825T194107]-API DATA -> is_charging - True
[20220825T194108]-API DATA -> cpu_usage - 5
[20220825T194116]-MAIN-Syncer Tick n:0
[20220825T194116]-API DATA -> wifi_state -
[20220825T194116]-API DATA -> battery_level - 26
[20220825T194116]-API DATA -> currently_active_window - Växla mellan aktiviteter
[20220825T194116]-API DATA -> uptime - 3723
[20220825T194116]-API DATA -> camera_in_use - False
[20220825T194116]-API DATA -> microphone_in_use - False
[20220825T194116]-API DATA -> location_in_use - True
[20220825T194116]-API DATA -> battery_state - Fully Charged
[20220825T194116]-API DATA -> free_ram - 944996
[20220825T194116]-API DATA -> wifi_ssid -
[20220825T194116]-API DATA -> is_charging - True
[20220825T194117]-API DATA -> cpu_usage - 12
[20220825T194126]-MAIN-Syncer Tick n:0
[20220825T194126]-API DATA -> battery_state - Fully Charged
[20220825T194126]-API DATA -> battery_level - 26
[20220825T194127]-API DATA -> free_ram - 946736
[20220825T194127]-API DATA -> currently_active_window - Växla mellan aktiviteter
[20220825T194127]-API DATA -> uptime - 3723
[20220825T194127]-API DATA -> camera_in_use - False
[20220825T194127]-API DATA -> microphone_in_use - False
[20220825T194127]-API DATA -> location_in_use - True
[20220825T194127]-API DATA -> wifi_state -
[20220825T194127]-API DATA -> is_charging - True
[20220825T194127]-API DATA -> cpu_usage - 9
[20220825T194129]-API DATA -> wifi_ssid -
[20220825T194136]-MAIN-Syncer Tick n:0
[20220825T194137]-API DATA -> battery_level - 27
[20220825T194137]-API DATA -> battery_state - Fully Charged
[20220825T194137]-API DATA -> free_ram - 937604
[20220825T194137]-API DATA -> wifi_state -
[20220825T194137]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194137]-API DATA -> uptime - 3723
[20220825T194137]-API DATA -> camera_in_use - False
[20220825T194137]-API DATA -> microphone_in_use - False
[20220825T194137]-API DATA -> location_in_use - True
[20220825T194137]-API DATA -> wifi_ssid -
[20220825T194138]-API DATA -> is_charging - True
[20220825T194138]-API DATA -> cpu_usage - 17
[20220825T194146]-MAIN-Syncer Tick n:0
[20220825T194146]-API DATA -> battery_level - 27
[20220825T194146]-API DATA -> battery_state - Fully Charged
[20220825T194147]-API DATA -> free_ram - 954248
[20220825T194148]-API DATA -> cpu_usage - 8
[20220825T194148]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194148]-API DATA -> uptime - 3723
[20220825T194148]-API DATA -> camera_in_use - False
[20220825T194148]-API DATA -> microphone_in_use - False
[20220825T194148]-API DATA -> location_in_use - True
[20220825T194148]-API DATA -> wifi_state -
[20220825T194148]-API DATA -> wifi_ssid -
[20220825T194148]-API DATA -> is_charging - True
[20220825T194156]-MAIN-Syncer Tick n:0
[20220825T194157]-API DATA -> battery_level - 27
[20220825T194157]-API DATA -> battery_state - Fully Charged
[20220825T194157]-API DATA -> free_ram - 927540
[20220825T194158]-API DATA -> cpu_usage - 13
[20220825T194158]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194158]-API DATA -> uptime - 3723
[20220825T194158]-API DATA -> camera_in_use - False
[20220825T194158]-API DATA -> microphone_in_use - False
[20220825T194158]-API DATA -> location_in_use - True
[20220825T194159]-API DATA -> wifi_ssid -
[20220825T194159]-API DATA -> is_charging - True
[20220825T194206]-MAIN-Syncer Tick n:0
[20220825T194207]-API DATA -> battery_state - Fully Charged
[20220825T194207]-API DATA -> battery_level - 27
[20220825T194208]-API DATA -> free_ram - 932648
[20220825T194208]-API DATA -> wifi_state -
[20220825T194208]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194208]-API DATA -> uptime - 3723
[20220825T194208]-API DATA -> camera_in_use - False
[20220825T194208]-API DATA -> microphone_in_use - False
[20220825T194208]-API DATA -> location_in_use - True
[20220825T194208]-API DATA -> wifi_ssid -
[20220825T194208]-API DATA -> is_charging - True
[20220825T194209]-API DATA -> cpu_usage - 18
[20220825T194216]-MAIN-Syncer Tick n:0
[20220825T194216]-API DATA -> battery_state - Fully Charged
[20220825T194216]-API DATA -> battery_level - 27
[20220825T194216]-API DATA -> free_ram - 907884
[20220825T194217]-API DATA -> wifi_state -
[20220825T194217]-API DATA -> wifi_ssid -
[20220825T194217]-API DATA -> uptime - 3723
[20220825T194217]-API DATA -> currently_active_window - Ny mapp
[20220825T194217]-API DATA -> camera_in_use - False
[20220825T194217]-API DATA -> microphone_in_use - False
[20220825T194217]-API DATA -> location_in_use - True
[20220825T194217]-API DATA -> is_charging - True
[20220825T194218]-API DATA -> cpu_usage - 8
[20220825T194226]-MAIN-Syncer Tick n:0
[20220825T194227]-API DATA -> battery_level - 28
[20220825T194227]-API DATA -> battery_state - Fully Charged
[20220825T194227]-API DATA -> free_ram - 882104
[20220825T194227]-API DATA -> wifi_state -
[20220825T194228]-API DATA -> cpu_usage - 25
[20220825T194228]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194228]-API DATA -> uptime - 3723
[20220825T194228]-API DATA -> camera_in_use - False
[20220825T194228]-API DATA -> microphone_in_use - False
[20220825T194228]-API DATA -> location_in_use - True
[20220825T194229]-API DATA -> is_charging - True
[20220825T194236]-MAIN-Syncer Tick n:0
[20220825T194236]-API DATA -> battery_level - 28
[20220825T194236]-API DATA -> wifi_ssid -
[20220825T194236]-API DATA -> battery_state - Fully Charged
[20220825T194237]-API DATA -> free_ram - 887700
[20220825T194238]-API DATA -> wifi_state -
[20220825T194238]-API DATA -> cpu_usage - 17
[20220825T194238]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194238]-API DATA -> uptime - 3723
[20220825T194238]-API DATA -> camera_in_use - False
[20220825T194238]-API DATA -> microphone_in_use - False
[20220825T194238]-API DATA -> location_in_use - True
[20220825T194238]-API DATA -> wifi_ssid -
[20220825T194238]-API DATA -> is_charging - True
[20220825T194246]-MAIN-Syncer Tick n:0
[20220825T194246]-API DATA -> battery_level - 28
[20220825T194246]-API DATA -> battery_state - Fully Charged
[20220825T194247]-API DATA -> free_ram - 870724
[20220825T194248]-API DATA -> wifi_state -
[20220825T194248]-API DATA -> cpu_usage - 53
[20220825T194248]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194248]-API DATA -> uptime - 3723
[20220825T194248]-API DATA -> camera_in_use - False
[20220825T194248]-API DATA -> microphone_in_use - False
[20220825T194248]-API DATA -> location_in_use - True
[20220825T194248]-API DATA -> wifi_ssid -
[20220825T194248]-API DATA -> is_charging - True
[20220825T194256]-MAIN-Syncer Tick n:0
[20220825T194257]-API DATA -> battery_level - 28
[20220825T194257]-API DATA -> battery_state - Fully Charged
[20220825T194257]-API DATA -> free_ram - 840012
[20220825T194259]-API DATA -> wifi_state -
[20220825T194259]-API DATA -> cpu_usage - 26
[20220825T194259]-API DATA -> currently_active_window - HA_Desktop_Companion - Share your Projects! - Home Assistant Community - Google Chrome
[20220825T194259]-API DATA -> uptime - 3723
[20220825T194259]-API DATA -> camera_in_use - False
[20220825T194259]-API DATA -> microphone_in_use - False
[20220825T194259]-API DATA -> location_in_use - True
[20220825T194300]-API DATA -> wifi_ssid -
[20220825T194300]-API DATA -> is_charging - True
[20220825T194306]-MAIN-Syncer Tick n:0
[20220825T194307]-API DATA -> battery_level - 28
[20220825T194307]-API DATA -> battery_state - Fully Charged
[20220825T194307]-API DATA -> free_ram - 826392
[20220825T194308]-API DATA -> cpu_usage - 9
[20220825T194308]-API DATA -> wifi_state -
[20220825T194308]-API DATA -> currently_active_window - HA_Desktop_Companion - Share your Projects! - Home Assistant Community - Google Chrome
[20220825T194308]-API DATA -> uptime - 3723
[20220825T194308]-API DATA -> camera_in_use - False
[20220825T194308]-API DATA -> microphone_in_use - False
[20220825T194308]-API DATA -> location_in_use - True
[20220825T194308]-API DATA -> wifi_ssid -
[20220825T194308]-API DATA -> is_charging - True
[20220825T194316]-MAIN-Syncer Tick n:0
[20220825T194317]-API DATA -> battery_state - Fully Charged
[20220825T194317]-API DATA -> battery_level - 29
[20220825T194317]-API DATA -> free_ram - 880064
[20220825T194319]-API DATA -> cpu_usage - 51
[20220825T194319]-API DATA -> currently_active_window - HA_Desktop_Companion - Share your Projects! - Home Assistant Community - Google Chrome
[20220825T194319]-API DATA -> uptime - 3723
[20220825T194319]-API DATA -> camera_in_use - False
[20220825T194319]-API DATA -> microphone_in_use - False
[20220825T194319]-API DATA -> location_in_use - True
[20220825T194319]-API DATA -> is_charging - True
[20220825T194326]-MAIN-Syncer Tick n:0
[20220825T194327]-API DATA -> battery_level - 29
[20220825T194328]-API DATA -> battery_state - Fully Charged
[20220825T194328]-API DATA -> wifi_ssid -
[20220825T194329]-API DATA -> free_ram - 884724
[20220825T194330]-API DATA -> cpu_usage - 40
[20220825T194330]-API DATA -> currently_active_window - log.txt - Anteckningar
[20220825T194330]-API DATA -> uptime - 3723
[20220825T194330]-API DATA -> camera_in_use - False
[20220825T194330]-API DATA -> microphone_in_use - False
[20220825T194330]-API DATA -> location_in_use - True
[20220825T194331]-API DATA -> wifi_ssid -
[20220825T194331]-API DATA -> is_charging - True
[20220825T194333]-API DATA -> wifi_state -
[20220825T194334]-API DATA -> cpu_temp -
[20220825T194334]-SENSOR-Read Outcome True
[20220825T194334]-API -> {"data":[{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_state","type":"sensor","state":"On AC","icon":"mdi:battery-minus"},{"unique_id":"battery_level","type":"sensor","state":"25","icon":"mdi:battery"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"free_ram","type":"sensor","state":964968,"icon":"mdi:clock"},{"unique_id":"is_charging","type":"binary_sensor","state":false,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":"35","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"Settings – Home Assistant - Google Chrome","icon":"mdi:application"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"free_ram","type":"sensor","state":925932,"icon":"mdi:clock"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"25","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"cpu_usage","type":"sensor","state":"34","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"battery_level","type":"sensor","state":"25","icon":"mdi:battery"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"free_ram","type":"sensor","state":866424,"icon":"mdi:clock"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":"14","icon":"mdi:cpu-64-bit"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"currently_active_window","type":"sensor","state":"Settings – Home Assistant - Google Chrome","icon":"mdi:application"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_level","type":"sensor","state":"25","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"free_ram","type":"sensor","state":824124,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"51","icon":"mdi:cpu-64-bit"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"currently_active_window","type":"sensor","state":"Settings – Home Assistant - Google Chrome","icon":"mdi:application"},{"unique_id":"camera_in_use","type":"binary_sensor","state":true,"icon":"mdi:camera"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_level","type":"sensor","state":"26","icon":"mdi:battery"},{"unique_id":"free_ram","type":"sensor","state":839964,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_usage","type":"sensor","state":"19","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"battery_level","type":"sensor","state":"26","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"free_ram","type":"sensor","state":906092,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"23","icon":"mdi:cpu-64-bit"},{"unique_id":"battery_level","type":"sensor","state":"26","icon":"mdi:battery"},{"unique_id":"currently_active_window","type":"sensor","state":"","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":910956,"icon":"mdi:clock"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":5,"icon":"mdi:cpu-64-bit"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_level","type":"sensor","state":"26","icon":"mdi:battery"},{"unique_id":"currently_active_window","type":"sensor","state":"Växla mellan aktiviteter","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":944996,"icon":"mdi:clock"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":"12","icon":"mdi:cpu-64-bit"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"battery_level","type":"sensor","state":"26","icon":"mdi:battery"},{"unique_id":"free_ram","type":"sensor","state":946736,"icon":"mdi:clock"},{"unique_id":"currently_active_window","type":"sensor","state":"Växla mellan aktiviteter","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},
{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":9,"icon":"mdi:cpu-64-bit"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_level","type":"sensor","state":"27","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":937604,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":"17","icon":"mdi:cpu-64-bit"},{"unique_id":"battery_level","type":"sensor","state":"27","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":954248,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":8,"icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"27","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":927540,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"13","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"battery_level","type":"sensor","state":"27","icon":"mdi:battery"},{"unique_id":"free_ram","type":"sensor","state":932648,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_usage","type":"sensor","state":"18","icon":"mdi:cpu-64-bit"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"battery_level","type":"sensor","state":"27","icon":"mdi:battery"},{"unique_id":"free_ram","type":"sensor","state":907884,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"currently_active_window","type":"sensor","state":"Ny mapp","icon":"mdi:application"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"cpu_usage","type":"sensor","state":8,"icon":"mdi:cpu-64-bit"},{"unique_id":"battery_level","type":"sensor","state":"28","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":882104,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_usage","type":"sensor","state":"25","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"28","icon":"mdi:battery"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":887700,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_usage","type":"sensor","state":"17","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"28","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":870724,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_usage","type":"sensor","state":"53","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"28","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":840012,"icon":"mdi:clock"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_usage","type":"sensor","state":"26","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"HA_Desktop_Companion - Share your Projects! - Home Assistant Community - Google Chrome","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"28","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"free_ram","type":"sensor","state":826392,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":9,"icon":"mdi:cpu-64-bit"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"currently_active_window","type":"sensor","state":"HA_Desktop_Companion - Share your Projects! - Home Assistant Community - Google Chrome","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"battery_level","type":"sensor","state":"29","icon":"mdi:battery"},{"unique_id":"free_ram","type":"sensor","state":880064,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"51","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"HA_Desktop_Companion - Share your Projects! - Home Assistant Community - Google Chrome","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"battery_level","type":"sensor","state":"29","icon":"mdi:battery"},{"unique_id":"battery_state","type":"sensor","state":"Fully Charged","icon":"mdi:battery-minus"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"free_ram","type":"sensor","state":884724,"icon":"mdi:clock"},{"unique_id":"cpu_usage","type":"sensor","state":"40","icon":"mdi:cpu-64-bit"},{"unique_id":"currently_active_window","type":"sensor","state":"log.txt - Anteckningar","icon":"mdi:application"},{"unique_id":"uptime","type":"sensor","state":3723,"icon":"mdi:timer-outline"},{"unique_id":"camera_in_use","type":"binary_sensor","state":false,"icon":"mdi:camera"},{"unique_id":"microphone_in_use","type":"binary_sensor","state":false,"icon":"mdi:microphone"},{"unique_id":"location_in_use","type":"binary_sensor","state":true,"icon":"mdi:crosshairs-gps"},{"unique_id":"wifi_ssid","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"is_charging","type":"binary_sensor","state":true,"icon":"mdi:power-plug-off"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"wifi_state","type":"sensor","state":"","icon":"mdi:wifi"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"},{"unique_id":"cpu_temp","type":"sensor","state":"","icon":"mdi:cpu-64-bit"}],"type":"update_sensor_states"}
[20220825T194335]-API CODE <- OK
[20220825T194335]-API <- "{\"uptime\": {\"success\": true}, \"location_in_use\": {\"success\": true}, \"wifi_state\": {\"success\": true}, \"battery_state\": {\"success\": true}, \"battery_level\": {\"success\": true}, \"wifi_ssid\": {\"success\": true}, \"free_ram\": {\"success\": true}, \"is_charging\": {\"success\": true}, \"cpu_usage\": {\"success\": true}, \"currently_active_window\": {\"success\": true}, \"camera_in_use\": {\"success\": true}, \"microphone_in_use\": {\"success\": true}, \"cpu_temp\": {\"success\": true}}"
[20220825T194335]-SENSOR-Read Outcome True
[20220825T194335]-API -> {"data":[],"type":"update_sensor_states"}
[20220825T194335]-API <- "{}"
[20220825T194336]-API CODE <- OK
[20220825T194336]-API <- "{}"
[20220825T194336]-SENSOR-Read Outcome True
[20220825T194336]-API -> {"data":[],"type":"update_sensor_states"}
[20220825T194337]-API CODE <- OK
[20220825T194337]-API <- "{}"
[20220825T194337]-MAIN-Syncer Tick n:0
[20220825T194337]-SENSOR-Read Outcome True
[20220825T194337]-API DATA SKIP -> location_in_use - True==True-SAME !
[20220825T194337]-API DATA SKIP -> currently_active_window - log.txt - Anteckningar==log.txt - Anteckningar-SAME !
[20220825T194337]-API DATA SKIP -> uptime - 3723==3723-SAME !
[20220825T194337]-API -> {"data":[],"type":"update_sensor_states"}
[20220825T194337]-API DATA SKIP -> camera_in_use - False==False-SAME !
[20220825T194337]-API DATA SKIP -> microphone_in_use - False==False-SAME !
#removed repetitive part to fit forum character limit.
[20220825T194338]-API <- "{}"
[20220825T194338]-SENSOR-Read Outcome True
[20220825T194338]-API -> {"data":[],"type":"update_sensor_states"}
[20220825T194338]-API CODE <- OK
[20220825T194339]-API CODE <- OK
[20220825T194339]-API <- "{}"
[20220825T194339]-SENSOR-Read Outcome True
[20220825T194339]-API -> {"data":[],"type":"update_sensor_states"}
So after a while it starts updating the sensors.
It’s slow. Now it seems to be stuck again.
I started the app with the camera on, and it took probably a minute for it to trigger on turning it off.
Then I turned it on and now it’s not updating to on.
While typing this I realized the app has silently crashed on me.
Stared it again and it crashed again without any notice.
I will try it later or tomorrow on my work PC .
When I have the app open and visible this message comes for a few seconds before it crashes.
hat is really it is working really well for me :frowning: not slow at all :frowning:
This part is really wierd it is reading the data but for some reason it is not sending them ?? is your personal computer slow or low on resources ?
I apologize for my crappy development but i try what i can it is hard for me to troubleshoot something when it is running for me :frowning:
If someone can please try this last version for today i tried that non ew laptop where it does not run before and it is stable https://github.com/GamerClassN7/HA_Desktop_Companion/releases/download/0.0.1-alpha-9/win-x64.zip
No worries. I understand the frustration and “developing in the dark”. It’s never a nice thing to do.
I wouldn’t say it’s slow. It’s not brand new. But I mean I can load most things in a few seconds and we use it for video editing fairly often. And that works fine.
So it shouldn’t be slow.
And since the values are updated in the log, not sure if it’s directly but within reason of the time it was done.
Will try the new version soon. Need to get my son in bed.
I really want to apologize to everyone i am really bad developer :frowning: I am mor of a web developer in IRL and this Windows stuff’s are really hard :frowning:
Hey! Cheer up! You have done a fantastic thing.
But I believe you that developing in a environment like Windows is hard.
Every time I need to use anything from Windows I more or less cry and try to find a way to solve it without.
Did a quick test.
It crashed with the same error message as the one posted above.
Got this line in the log at the very end:
[20220825T203816]-System.ArgumentException: Only Uris starting with 'ws://' or 'wss://' are supported. (Parameter 'uri')
   at System.Net.WebSockets.ClientWebSocket.Co
