I want to share my latest project. if you are like me and you don’t like MQTT for what ever reason. and still want to get interesting data from your computer to home assistant, from triggering lights music and other stuff based on your work you are doing on your computer. HA Desktop Companion is there for you
All feedback i appreciated
tom_l
August 16, 2022, 6:27am
2
Does it have a CPU package temperature sensor?
Where are the install instructions?
It has but not in public build, install instruction are simple donwload it and runn it (you need to fill in only your HA URL and token)
tom_l
August 16, 2022, 6:31am
4
One last question, can it be run as a service that starts when windows starts?
yes you can simply create symlink to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup and program starts on startup.
do you want me to send you dev ´version with CPU temp ?
tom_l
August 16, 2022, 7:09am
6
Yes please. I’ll give it a go later tonight.
tom_l
August 16, 2022, 7:35am
9
I’ll just ask for support from atx in #off-topic
JonatanRek
(JonatanRek)
August 16, 2022, 9:08am
10
tom_l
August 16, 2022, 9:18am
11
Joke. He did your readme PR.
Sensor suggestions:
% memory use
CPU load
GPU temperature
JonatanRek
(JonatanRek)
August 16, 2022, 9:29am
12
Little Sneak Peak
GPU Will be harder since there can be more than One,
i will do CPU tomorrow hopefully
EDIT: Hopefully with autoupdate mechnic in place
JonatanRek
(JonatanRek)
August 16, 2022, 9:31am
13
Also: dont know if i made ti faill pruve enoug to run on nay PC so if it crash there should be a log.txt in directory with exe
Hellis81
(Hellis81)
August 16, 2022, 9:34am
14
Where is the exe file?
I can only find HA_Desktop_Companion.csproj
or HA_Desktop_Companion.sln
JonatanRek
(JonatanRek)
August 16, 2022, 9:36am
15
JonatanRek
(JonatanRek)
August 16, 2022, 9:39am
16
you need to download the zipfile end extract it
Hellis81
(Hellis81)
August 16, 2022, 9:41am
17
Ok… But from the first link you posted, where do you get to that page.
I’m not used to GitHub, but I can’t find the second page from the first page.
I thought you downloaded from here:
JonatanRek
(JonatanRek)
August 16, 2022, 9:44am
18
Ok, but last link is right to release download page
tom_l
August 16, 2022, 9:58am
19
I click YES but nothing happens:
Hellis81
(Hellis81)
August 16, 2022, 9:59am
20
tom_l
August 16, 2022, 10:01am
21
It does not. But thanks for the link.
Installed but I still get the same error.
