HA Docker and MQTT, EspHome, Zigbee2Mqtt with same IPs in the same VLAN
Hi All,
I currently have Home Assistant OS in a Unraid VM including MQTT, EspHome, Zigbee2Mqtt with ip 192,168.20.5 in my IOT VLAN.
I will like to reproduce the same configuraiou in the Unraid Docker Container, basically reach multiple Unraid docker containers with same IP 192.168.20.5 that expose different ports, its that possible?
I also have the problem that when I select the second container with Network type: Custom: br0.20 – IOT it will fails.
docker: Error response from daemon: Address already in use.
Is it possible to have multiple containers on the same IP in a VLAN that share different ports?
What is your suggestion to use Home assistant, MQTT, EspHome, Zigbee2Mqtt in containers on a VLAN?
John
