HA Docker Container Upgrade Error
I just did what I normally do to update HA via Portainer - hit the “recreate image” button and pulled the latest. I was on .103 so I’m assuming I was going to upgrade to .112. However, I get the following error after upgrading and when trying to start the container:
Any thoughts?
As the error says the “entry point” for the HA Docker container changed from “entry.sh” to “init” at some point in the last several updates.
You can either edit your existing container and redeploy it or even easier just remove the existing container and re-create it as you did when you first installed HA in docker. the new image contains the correct entry point update.
Thank you!!
