HA does not register successive 'on' presses for ZWave wall switch
I’m trying to set up HA with a ZWave network, but I can’t get my battery wall switch to work to my liking (ZWave.me 064435). It has a paddle that I can press ‘on’ or ‘off’. Pressing ‘on’ sends a BASIC signal with value 255, ‘off’ sends the same signal with value 0.
I’ve managed to get it to register by updating components/zwave.py (badly - see below).
HA can correctly see the switch sending ‘on’ and ‘off’ events. When I tap the switch, it registers that the state changes to ‘on’ (255) and the track_state_change handler is correctly executed.
However, when I tap it again (‘on’), the event arrives in HA (in components/switch/zwave.py in _value_changed(self, value), but since the value did not actually change (255 -> 255), it never arrives in the track_state_change handler.
What I would like is to have the ‘on’ button cycle through different scenes.
Is something like that possible?
Below, my (makeshift) changes to get the switch to register:
# components/zwave.py
COMMAND_CLASS_BASIC = 32 # 0x20
DISCOVERY_COMPONENTS = [
  ('switch',
   DISCOVER_SWITCHES,
   [COMMAND_CLASS_SWITCH_BINARY,
    COMMAND_CLASS_BASIC], # here
   TYPE_WHATEVER,  # here
   GENRE_WHATEVER), # here
# components/switch/zwave.py
  def setup_platform(hass, config,add_devices, discovery_info=None):
    # Should of course be handled in a nicer way.
    if value.command_class == zwave.COMMAND_CLASS_BASIC:
      add_devices([ZwaveBasicSwitch(value)])
    else
      # Original code for adding switches
The ZwaveBasicSwitch that I’ve created is just a subclass of ZwaveSwitch with no extra functionality.
I’ve tried a (dirty!) workaround that overrides ZwaveBasicSwitch._value_changed(..) and internally changes the 255-value to something new, but I could not get that to work.
I have also tried it as a Sensor, which worked but with the same limitations.
I think my best bet is to use ZwaveTriggerSensor (which has no memory and would trigger the track_state_change handler), but that seems to temporarily set a high value and then automatically resets it to ‘0’ (which would correspond to an ‘off’ press on my switch).
Does anyone have an idea how I can add the switch and have the correct behavior for ‘on’ (multiple presses to cycle between programmes) and ‘off’ (turn off lights)?
Thanks!
Very much interested in this also. Did you ever get this to Work?
Looking for something like this as well, but for double and triple taps.
