HA doesn't complete the startup
I pulled latest stable release of HA for docker. I restarted the container but it looks that HA no longer complete the startup.
I have just a couple of errors but they shouldn’t stuck HA startup.
The web page stucks telling “Unable to connect to Home Assistant.”
Do you have any idea?
Thank You
M.
here you are the log:
2019-12-17 16:21:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-17 16:21:10 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-17 16:21:10 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds.
2019-12-17 16:21:10 INFO (MainThread) [homeassistant.setup] Setting up http
2019-12-17 16:21:10 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2019-12-17 16:21:10 INFO (MainThread) [homeassistant.setup] Setting up system_log
2019-12-17 16:21:10 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2019-12-17 16:21:11 INFO (MainThread) [homeassistant.setup] Setting up recorder
2019-12-17 16:21:11 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.2 seconds.
2019-12-17 16:21:11 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2019-12-17 16:21:11 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setting up discovery
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2019-12-17 16:21:12 INFO (SyncWorker_4) [homeassistant.loader] Loaded darksky from homeassistant.components.darksky
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setting up group
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setting up duckdns
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setup of domain duckdns took 0.1 seconds.
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setting up updater
2019-12-17 16:21:12 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2019-12-17 16:21:13 INFO (SyncWorker_19) [homeassistant.util.package] Attempting install of alexapy==1.3.2
2019-12-17 16:21:13 INFO (SyncWorker_13) [homeassistant.loader] Loaded ping from homeassistant.components.ping
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up zone
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up sun
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up alexa
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain alexa took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up system_health
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up auth
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up conversation
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up api
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up history
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.ping
2019-12-17 16:21:13 INFO (SyncWorker_10) [homeassistant.loader] Loaded samsungtv from homeassistant.components.samsungtv
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up webhook
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up config
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up dialogflow
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain dialogflow took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.1 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.6 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.helpers.storage] Migrating onboarding storage from 1 to 3
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.1 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain group took 1.1 seconds.
2019-12-17 16:21:13 INFO (SyncWorker_3) [homeassistant.loader] Loaded bluetooth_tracker from homeassistant.components.bluetooth_tracker
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up script
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setting up automation
2019-12-17 16:21:13 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2019-12-17 16:21:17 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 4.4 seconds.
2019-12-17 16:21:17 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.updater
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setting up alexa_media
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setup of domain alexa_media took 0.0 seconds.
2019-12-17 16:22:06 INFO (MainThread) [custom_components.alexa_media]
alexa_media
Version: 2.3.4
This is a custom component
If you have any issues with this you need to open an issue here:
https://github.com/custom-components/alexa_media_player/issues
2019-12-17 16:22:06 INFO (MainThread) [custom_components.alexa_media] Loaded alexapy==1.3.2
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setting up deconz
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setup of domain deconz took 0.0 seconds.
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setting up tplink
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setup of domain tplink took 0.0 seconds.
2019-12-17 16:22:06 INFO (MainThread) [homeassistant.setup] Setting up notify
2019-12-17 16:22:07 INFO (SyncWorker_6) [homeassistant.loader] Loaded template from homeassistant.components.template
2019-12-17 16:22:07 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2019-12-17 16:22:07 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.0 seconds.
2019-12-17 16:22:08 INFO (MainThread) [homeassistant.setup] Setting up media_player
2019-12-17 16:22:09 INFO (SyncWorker_19) [homeassistant.loader] Loaded time_date from homeassistant.components.time_date
2019-12-17 16:22:09 INFO (MainThread) [homeassistant.setup] Setting up ifttt
2019-12-17 16:22:09 INFO (MainThread) [homeassistant.setup] Setup of domain ifttt took 0.0 seconds.
2019-12-17 16:22:09 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2019-12-17 16:22:09 INFO (MainThread) [homeassistant.setup] Setting up frontend
2019-12-17 16:22:09 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.setup] Setting up device_tracker
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.setup] Setting up logbook
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.setup] Setting up map
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.deconz
2019-12-17 16:22:10 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 1.1 seconds.
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.samsungtv
2019-12-17 16:22:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded light from homeassistant.components.light
2019-12-17 16:22:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2019-12-17 16:22:11 INFO (SyncWorker_5) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2019-12-17 16:22:11 INFO (SyncWorker_4) [homeassistant.components.samsungtv] Samsung TV 10.9.10.54 added as 'TV_sala'
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setting up climate
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds.
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setting up scene
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.components.climate] Setting up climate.deconz
2019-12-17 16:22:11 INFO (SyncWorker_1) [homeassistant.util.package] Attempting install of attrs==19.2.0
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setting up light
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.5 seconds.
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.components.scene] Setting up scene.deconz
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 3.0 seconds.
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.1 seconds.
2019-12-17 16:22:11 INFO (MainThread) [homeassistant.components.light] Setting up light.deconz
2019-12-17 16:22:21 INFO (SyncWorker_18) [homeassistant.loader] Loaded alarm_control_panel from homeassistant.components.alarm_control_panel
2019-12-17 16:22:21 INFO (MainThread) [homeassistant.setup] Setting up alarm_control_panel
2019-12-17 16:22:21 INFO (MainThread) [homeassistant.setup] Setup of domain alarm_control_panel took 0.0 seconds.
2019-12-17 16:22:21 INFO (MainThread) [homeassistant.components.notify] Setting up notify.alexa_media
2019-12-17 16:22:21 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.alexa_media
2019-12-17 16:22:21 INFO (MainThread) [homeassistant.components.alarm_control_panel] Setting up alarm_control_panel.alexa_media
2019-12-17 16:22:25 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 19.0 seconds.
2019-12-17 16:22:25 INFO (MainThread) [homeassistant.components.notify] Setting up notify.alexa_media
2019-12-17 16:22:31 WARNING (MainThread) [homeassistant.components.alarm_control_panel] Setup of platform alexa_media is taking over 10 seconds.
2019-12-17 16:22:41 INFO (SyncWorker_8) [homeassistant.util.package] Attempting install of aiogithubapi==0.4.2
2019-12-17 16:23:21 ERROR (MainThread) [homeassistant.components.alarm_control_panel] Setup of platform alexa_media is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2019-12-17 16:23:25 INFO (SyncWorker_13) [homeassistant.util.package] Attempting install of backoff==1.8.0
2019-12-17 16:23:56 INFO (SyncWorker_7) [homeassistant.util.package] Attempting install of integrationhelper==0.2.2
2019-12-17 16:24:38 INFO (SyncWorker_9) [homeassistant.util.package] Attempting install of semantic_version==2.8.2
2019-12-17 16:25:11 INFO (MainThread) [homeassistant.setup] Setting up hacs
2019-12-17 16:25:11 INFO (MainThread) [hacs]
HACS (Home Assistant Community Store)
Version: 0.16.3
This is a custom integration
https://github.com/hacs/integration/issues
2019-12-17 16:25:12 INFO (MainThread) [homeassistant.components.device_tracker] Setting up device_tracker.legacy
2019-12-17 16:25:13 INFO (MainThread) [homeassistant.setup] Setting up cover
2019-12-17 16:25:13 INFO (MainThread) [homeassistant.setup] Setting up switch
2019-12-17 16:25:13 INFO (MainThread) [homeassistant.components.cover] Setting up cover.mqtt
2019-12-17 16:25:13 INFO (MainThread) [homeassistant.components.cover] Setting up cover.group
2019-12-17 16:25:13 INFO (MainThread) [homeassistant.components.switch] Setting up switch.mqtt
2019-12-17 16:25:13 INFO (MainThread) [homeassistant.setup] Setup of domain device_tracker took 183.2 seconds.
2019-12-17 16:25:14 INFO (MainThread) [homeassistant.setup] Setting up ios
2019-12-17 16:25:14 INFO (MainThread) [homeassistant.setup] Setup of domain ios took 0.4 seconds.
2019-12-17 16:25:14 INFO (MainThread) [homeassistant.components.notify] Setting up notify.ios
2019-12-17 16:25:15 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 2.0 seconds.
2019-12-17 16:25:15 INFO (MainThread) [homeassistant.components.cover] Setting up cover.deconz
2019-12-17 16:25:16 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 2.8 seconds.
2019-12-17 16:25:16 INFO (MainThread) [homeassistant.components.switch] Setting up switch.tplink
2019-12-17 16:25:16 INFO (MainThread) [homeassistant.components.switch] Setting up switch.deconz
2019-12-17 16:25:16 INFO (MainThread) [homeassistant.components.switch] Setting up switch.alexa_media
2019-12-17 16:25:19 INFO (MainThread) [hacs.repository.integration.hacs.integration] Registration complete
2019-12-17 16:25:21 INFO (MainThread) [hacs.data] Restore started
2019-12-17 16:25:21 INFO (MainThread) [hacs.data] Restore done
2019-12-17 16:25:21 INFO (MainThread) [homeassistant.setup] Setup of domain hacs took 10.1 seconds.
2019-12-17 16:25:22 INFO (MainThread) [homeassistant.setup] Setting up sensor
2019-12-17 16:25:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.time_date
2019-12-17 16:25:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mqtt
2019-12-17 16:25:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.darksky
2019-12-17 16:25:22 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.template
2019-12-17 16:25:25 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.deconz
2019-12-17 16:25:25 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.alexa_media
2019-12-17 16:25:25 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ios
2019-12-17 16:25:25 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hacs
2019-12-17 16:25:26 WARNING (MainThread) [homeassistant.components.switch] Setup of platform tplink is taking over 10 seconds.
2019-12-17 16:25:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:26:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:26:16 ERROR (MainThread) [homeassistant.components.switch] Setup of platform tplink is taking longer than 60 seconds. Startup will proceed without waiting any longer.
2019-12-17 16:26:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:27:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:27:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:28:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:28:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:29:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:29:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:30:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:30:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:31:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:31:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:32:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:32:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:32:33 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:33:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:33:03 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:33:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:33:33 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:34:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:34:03 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:34:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:34:33 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:35:02 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:35:03 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:35:32 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12-17 16:35:33 WARNING (MainThread) [homeassistant.components.mqtt.cover] Payload is not integer within range:
2019-12
Did you try in your mqtt config:
retain: true
Seems to be a mqtt problem.
I don’t want that mqtt broker retains messages. I had some problem in the past with Shellies switches that looked to bring to life doing some unwanted actions due to values retained from mqtt broker…
Same issue here
I am personnaly approaching the 12th hour of debugging without success…
In the logs nothing interesting…
In debug mode they are “too much” for me.
I also reverted to 0.100.3 but same issue.
It there any “cache” file I can delete that HA rebuilt during the startup?
Phelps it could be something related some file corruption…
I am now in the same boat… Either of you make any progress?
Sorry but I’m still there.
I think i just solved it… For me, it seems to be nodered and/or my mqtt server from hassio “MQTT Server & Web client”. I stopped them both and hass is stable and capable of starting up again
EDIT: ok - I found my issue… zigbee2mqtt was flooding my mqtt server w/ 1000s message per second.
I gave up. Troubleshooting seemed impossible.
I started from scratch using hassio this time.
I’m not so happy…
There were more guys here with same problem after update to 0.103.x.
Solution was sometimes to disable the custom components → see warnings in log
