One of my errors was about wake_on_lan. A change I saw in the 103 change log, but then forgot to update in my configuration.yaml. I made that change (mac_address to mac) and restarted the homeassistant docker.
I’m still not getting the front end up, but the log files seem to just have errors saying that something can’t communicate with homeassistant. I’m confused by the vesync error (because I commented those lines out of my config file to take that out of account:
2019-12-11 18:29:44 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for vesync which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-11 18:29:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component vesync
File "/usr/src/homeassistant/homeassistant/setup.py", line 176, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File "/config/custom_components/vesync/__init__.py", line 26, in setup
conf = config[DOMAIN]
KeyError: 'vesync'
2019-12-11 18:30:15 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 157, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 672, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 387, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.7/http/client.py", line 1252, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1298, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1247, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.7/http/client.py", line 1026, in _send_output
self.send(msg)
File "/usr/local/lib/python3.7/http/client.py", line 966, in send
self.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 184, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 169, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xabc45d10>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 720, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 436, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.2.14', port=8060): Max retries exceeded with url: /query/device-info (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xabc45d10>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/src/homeassistant/homeassistant/components/roku/__init__.py", line 52, in roku_discovered
_setup_roku(hass, config, {CONF_HOST: info["host"]})
File "/usr/src/homeassistant/homeassistant/components/roku/__init__.py", line 104, in _setup_roku
r_info = roku.device_info
File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 258, in device_info
resp = self._get('/query/device-info')
File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 207, in _get
return self._call('GET', path, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 224, in _call
resp = func(url, timeout=self.timeout, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.2.14', port=8060): Max retries exceeded with url: /query/device-info (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xabc45d10>: Failed to establish a new connection: [Errno 111] Connection refused'))
raise err
sock.connect(sa)
chunked=chunked,
self.send(msg)
self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0xabc45f30>: Failed to establish a new connection: [Errno 111] Connection refused
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.2.14', port=8060): Max retries exceeded with url: /query/device-info (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xabc45f30>: Failed to establish a new connection: [Errno 111] Connection refused'))
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.2.14', port=8060): Max retries exceeded with url: /query/device-info (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0xabc45f30>: Failed to establish a new connection: [Errno 111] Connection refused'))
