I am new to the home automation world. I do have some computer background. I tried setting up a RBpi 4 with home assistant a couple or 3 years ago with limited luck. I had been watching some YouTube videos and saw one about running home assistant.
WOW! It looked easy!
So I broke out my raspberry pi, downloaded a new home assistant image, and was off to the races down the rabbit hole.
Everything has been going great. Even been playing with some Yaml files.
I have now run into a few problems which I will only address NFC tags in this topic.
I have created them. But after I do, I have noticed that all of the tag information is gone out of the tags that I created in home assistant in the list of tags. I noticed this when I tried creating another tag. I looked in automations.yaml and the information is in there.
I don’t like working on a phone. So, I create the automations on my computer and then write them to a tag on my phone. Just wondering why am losing the information and set up of the tag in home assistant.
If I ‘programmed’ and I want to change that tag, then - when I click the tag - I would expect to see what is already programmed and to be able to adjust it.
If I open it now, it is empty. When I then add a new automation and save it, it is saved in the automations as en new automation:
I think now that the ‘Tags’ menu item is only meant for creating tags. But then: why
display the already created tags? Confusing to me, but now I think I’ll manage optimizing my tag-automations.
You didn’t program the tag, you programmed what home assistant does when you scan the tag. It belongs with all the other home assistant automations go.
Yes, that is how I understood it. Let me rephrase: “I think now that the ‘Tags’ menu item is only meant for creating tags managing the connection between tag and automation.”
Still: if I open a tag in the ‘Tags’ menu in HA, I would expect to see what HA does after scanning. In other words: I would expect to see the automation that is already configured and not a new automation.
With current functionality it is possible to connect multiple automations to one tag, but I don’t see the point in that: you could have one automation per tag with multiple actions, so imo no need for more than one automation per tag.
