from the very begining of my journey with HA I have problems with my Google Mini and Chromecast.
I think I tried everything, but maybe you can guide me what to do.
First of all - I’m using HA on QNAP as a docker container - release 2020.12.1.
I have Asus as my home router: one subnet, Wifi - only 2.4.
Right now I have those integrations:
- HACS
- sonoff (from HACS)
- weather - AccuWeather, OpenWeather
- Shelly
- Samsung SmartTV
- MobileApp
- Google Cast
Some Automations, scenes, … and cloud access from NabuCasa.
Everything works without problem till…
… something is breaking connection to one of casts (some router restart, wifi breaks, etc).
For sure - if I plug off my GH mini it stays unavailable after pluging in.
WIthout doing any changes - restart of HA and everything is fine!
No… creating automation for that it’s not an answer Any other will be welcome
My conf:
homeassistant:
customize: !include customize.yaml
unit_system: metric
time_zone: Europe/Warsaw
internal_url: "http://10.10.xx.xx:8123"
binary_sensor:
sensors:
anyone_home:
device_class: occupancy
value_template: >
{{ states.person | selectattr('state','eq','home') | list | count > 0 }}
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sonoff:
username: [email protected]
password: !secret ewelink.pass
light:
- platform: switch
entity_id: switch.sonoff_1xxxxxxxx34_1
- platform: switch
entity_id: switch.sonoff_1xxxxxxxx34_2
- platform: group
entities:
- light.IN
- light.OUT
logger:
default: info
logs:
homeassistant.components.cast: debug
homeassistant.components.cast.media_player: debug
pychromecast: debug
pychromecast.discovery: debug
pychromecast.socket_client: debug
homeassistant.components.zeroconf: debug
zeroconf: debug
Related logs:
2020-12-22 09:33:17 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-22 09:33:18 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Creating new socket with port 5353, ip_version IPVersion.V4Only, apple_p2p False and bind_addr ('10.0.5.1',)
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Created socket <socket.socket fd=10, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.0.5.1', 5353)>
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Configuring socket <socket.socket fd=10, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.0.5.1', 5353)> with multicast interface 10.0.5.1
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Adding '10.10.xx.xxx' (socket 7) to multicast group
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Creating new socket with port 5353, ip_version IPVersion.V4Only, apple_p2p False and bind_addr ('10.10.xx.xxx',)
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Created socket <socket.socket fd=11, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.10.xx.xxx', 5353)>
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Configuring socket <socket.socket fd=11, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.10.xx.xxx', 5353)> with multicast interface 10.10.xx.xxx
2020-12-22 09:33:22 DEBUG (SyncWorker_2) [zeroconf] Listen socket <socket.socket fd=7, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('0.0.0.0', 5353)>, respond sockets [<socket.socket fd=8, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('127.0.0.1', 5353)>, <socket.socket fd=9, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.0.3.1', 5353)>, <socket.socket fd=10, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.0.5.1', 5353)>, <socket.socket fd=11, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=0, laddr=('10.10.xx.xxx', 5353)>]
2020-12-22 09:33:22 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.204':5353 (socket 7): <DNSIncoming:{id=0, flags=33792, n_q=0, n_ans=1, n_auth=0, n_add=3, questions=[], answers=[record[ptr,in,_googlezone._tcp.local.]=120/119,1e15f534-89e4-51cc-eb33-00a249d738d9._googlezone._tcp.local., record[txt,in-unique,1e15f534-89e4-51cc-eb33-00a249d738d9._googlezone._tcp.local.]=4500/4499,b'#id=F75'..., record[srv,in-unique,1e15f534-89e4-51cc-eb33-00a249d738d9._googlezone._tcp.local.]=120/119,1e15f534-89e4-51cc-eb33-00a249d738d9.local.:10001, record[a,in-unique,1e15f534-89e4-51cc-eb33-00a249d738d9.local.]=120/119,10.10.xx.204]}> (269 bytes) as [b"\x00\x00\x84\x00\x00\x00\x00\x01\x00\x00\x00\x03\x0b_googlezone\x04_tcp\x05local\x00\x00\x0c\x00\x01\x00\x00\x00x\x00'$1e15f534-89e4-51cc-eb33-00a249d738d9\xc0\x0c\xc0.\x00\x10\x80\x01\x00\x00\x11\x94\x00c#id=F752719F147CC03DE6276D279DDD069C*b2b239a0-a618-412a-9597-bec5e10eacb9=8|All\x13__common_time__=0|0\xc0.\x00!\x80\x01\x00\x00\x00x\x00-\x00\xd2\xff\xff'\x11$1e15f534-89e4-51cc-eb33-00a249d738d9\xc0\x1d\xc0\xd6\x00\x01\x80\x01\x00\x00\x00x\x00\x04\n\n\x01\xcc"]
2020-12-22 09:33:22 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.204':5353 (socket 7): <DNSIncoming:{id=0, flags=0, n_q=1, n_ans=0, n_auth=0, n_add=0, questions=[question[srv,in,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6._googlezone._tcp.local.]], answers=[]}> (77 bytes) as [b'\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00$0ffe556a-e1d3-fd68-25c8-aeaefe122bb6\x0b_googlezone\x04_tcp\x05local\x00\x00!\x00\x01']
2020-12-22 09:33:22 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.204':5353 (socket 7): <DNSIncoming:{id=0, flags=33792, n_q=0, n_ans=1, n_auth=0, n_add=3, questions=[], answers=[record[ptr,in,_googlerpc._tcp.local.]=120/119,googlerpc._googlerpc._tcp.local., record[txt,in-unique,googlerpc._googlerpc._tcp.local.]=4500/4499,b'#cd=F75'..., record[srv,in-unique,googlerpc._googlerpc._tcp.local.]=120/119,1e15f534-89e4-51cc-eb33-00a249d738d9.local.:8012, record[a,in-unique,1e15f534-89e4-51cc-eb33-00a249d738d9.local.]=120/119,10.10.xx.204]}> (178 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x01\x00\x00\x00\x03\n_googlerpc\x04_tcp\x05local\x00\x00\x0c\x00\x01\x00\x00\x00x\x00\x0c\tgooglerpc\xc0\x0c\xc0-\x00\x10\x80\x01\x00\x00\x11\x94\x00$#cd=F752719F147CC03DE6276D279DDD069C\xc0-\x00!\x80\x01\x00\x00\x00x\x00-\x00\x00\x00\x00\x1fL$1e15f534-89e4-51cc-eb33-00a249d738d9\xc0\x1c\xc0{\x00\x01\x80\x01\x00\x00\x00x\x00\x04\n\n\x01\xcc']
2020-12-22 09:33:22 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.177':5353 (socket 7): <DNSIncoming:{id=0, flags=33792, n_q=0, n_ans=1, n_auth=0, n_add=3, questions=[], answers=[record[ptr,in,_googlerpc._tcp.local.]=120/119,googlerpc-1._googlerpc._tcp.local., record[txt,in-unique,googlerpc-1._googlerpc._tcp.local.]=4500/4499,b'#cd=74B'..., record[srv,in-unique,googlerpc-1._googlerpc._tcp.local.]=120/119,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6.local.:8012, record[a,in-unique,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6.local.]=120/119,10.10.xx.177]}> (180 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x01\x00\x00\x00\x03\n_googlerpc\x04_tcp\x05local\x00\x00\x0c\x00\x01\x00\x00\x00x\x00\x0e\x0bgooglerpc-1\xc0\x0c\xc0-\x00\x10\x80\x01\x00\x00\x11\x94\x00$#cd=74B472FD173B416613129AA68976F2EB\xc0-\x00!\x80\x01\x00\x00\x00x\x00-\x00\x00\x00\x00\x1fL$0ffe556a-e1d3-fd68-25c8-aeaefe122bb6\xc0\x1c\xc0}\x00\x01\x80\x01\x00\x00\x00x\x00\x04\n\n\x01\xb1']
2020-12-22 09:33:22 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.177':5353 (socket 7): <DNSIncoming:{id=0, flags=33792, n_q=0, n_ans=1, n_auth=0, n_add=1, questions=[], answers=[record[srv,in-unique,googlerpc-1._googlerpc._tcp.local.]=120/119,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6.local.:8012, record[a,in-unique,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6.local.]=120/119,10.10.xx.177]}> (118 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x01\x00\x00\x00\x01\x0bgooglerpc-1\n_googlerpc\x04_tcp\x05local\x00\x00!\x80\x01\x00\x00\x00x\x00-\x00\x00\x00\x00\x1fL$0ffe556a-e1d3-fd68-25c8-aeaefe122bb6\xc0(\xc0?\x00\x01\x80\x01\x00\x00\x00x\x00\x04\n\n\x01\xb1']
2020-12-22 09:33:22 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.177':5353 (socket 7): <DNSIncoming:{id=0, flags=33792, n_q=0, n_ans=1, n_auth=0, n_add=3, questions=[], answers=[record[ptr,in,_googlezone._tcp.local.]=120/119,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6._googlezone._tcp.local., record[txt,in-unique,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6._googlezone._tcp.local.]=4500/4499,b'#id=74B'..., record[srv,in-unique,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6._googlezone._tcp.local.]=120/119,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6.local.:10001, record[a,in-unique,0ffe556a-e1d3-fd68-25c8-aeaefe122bb6.local.]=120/119,10.10.xx.177]}> (271 bytes) as [b"\x00\x00\x84\x00\x00\x00\x00\x01\x00\x00\x00\x03\x0b_googlezone\x04_tcp\x05local\x00\x00\x0c\x00\x01\x00\x00\x00x\x00'$0ffe556a-e1d3-fd68-25c8-aeaefe122bb6\xc0\x0c\xc0.\x00\x10\x80\x01\x00\x00\x11\x94\x00e#id=74B472FD173B416613129AA68976F2EB*b2b239a0-a618-412a-9597-bec5e10eacb9=1|All\x15__common_time__=1|158\xc0.\x00!\x80\x01\x00\x00\x00x\x00-\x02b\xff\xfc'\x11$0ffe556a-e1d3-fd68-25c8-aeaefe122bb6\xc0\x1d\xc0\xd8\x00\x01\x80\x01\x00\x00\x00x\x00\x04\n\n\x01\xb1"]
2020-12-22 09:33:28 DEBUG (SyncWorker_5) [homeassistant.components.cast.discovery] Starting internal pychromecast discovery
2020-12-22 09:33:28 DEBUG (Thread-5) [zeroconf] offsets = 0, 0, 0
2020-12-22 09:33:28 DEBUG (Thread-5) [zeroconf] lengths = 3, 0, 0
2020-12-22 09:33:28 DEBUG (Thread-5) [zeroconf] now offsets = 3, 0, 0
2020-12-22 09:33:28 DEBUG (Thread-5) [zeroconf] Sending (229 bytes #1) <DNSOutgoing:{multicast=True, flags=0, questions=[question[ptr,in,_googlecast._tcp.local.]], answers=[(record[ptr,in,_googlecast._tcp.local.]=120/114,Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6._googlecast._tcp.local., 1608626008080.757), (record[ptr,in,_googlecast._tcp.local.]=120/114,Google-Cast-Group-b2b239a0a618412a9597bec5e10eacb9-1._googlecast._tcp.local., 1608626008080.757), (record[ptr,in,_googlecast._tcp.local.]=120/114,Chromecast-1e15f53489e451cceb3300a249d738d9._googlecast._tcp.local., 1608626008080.757)], authorities=[], additionals=[]}> as b'\x00\x00\x00\x00\x00\x01\x00\x03\x00\x00\x00\x00\x0b_googlecast\x04_tcp\x05local\x00\x00\x0c\x00\x01\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x0041Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6\xc0\x0c\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x0074Google-Cast-Group-b2b239a0a618412a9597bec5e10eacb9-1\xc0\x0c\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x00.+Chromecast-1e15f53489e451cceb3300a249d738d9\xc0\x0c'...
2020-12-22 09:33:28 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '127.0.0.1':5353 (socket 7): <DNSIncoming:{id=0, flags=0, n_q=1, n_ans=3, n_auth=0, n_add=0, questions=[question[ptr,in,_googlecast._tcp.local.]], answers=[record[ptr,in,_googlecast._tcp.local.]=114/113,Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6._googlecast._tcp.local., record[ptr,in,_googlecast._tcp.local.]=114/113,Google-Cast-Group-b2b239a0a618412a9597bec5e10eacb9-1._googlecast._tcp.local., record[ptr,in,_googlecast._tcp.local.]=114/113,Chromecast-1e15f53489e451cceb3300a249d738d9._googlecast._tcp.local.]}> (229 bytes) as [b'\x00\x00\x00\x00\x00\x01\x00\x03\x00\x00\x00\x00\x0b_googlecast\x04_tcp\x05local\x00\x00\x0c\x00\x01\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x0041Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6\xc0\x0c\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x0074Google-Cast-Group-b2b239a0a618412a9597bec5e10eacb9-1\xc0\x0c\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x00.+Chromecast-1e15f53489e451cceb3300a249d738d9\xc0\x0c']
2020-12-22 09:33:28 DEBUG (zeroconf-Engine-157) [zeroconf] Ignoring duplicate message received from '10.0.3.1':5353 (socket 7) (229 bytes) as [b'\x00\x00\x00\x00\x00\x01\x00\x03\x00\x00\x00\x00\x0b_googlecast\x04_tcp\x05local\x00\x00\x0c\x00\x01\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x0041Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6\xc0\x0c\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x0074Google-Cast-Group-b2b239a0a618412a9597bec5e10eacb9-1\xc0\x0c\xc0\x0c\x00\x0c\x00\x01\x00\x00\x00r\x00.+Chromecast-1e15f53489e451cceb3300a249d738d9\xc0\x0c']
2020-12-22 09:33:28 DEBUG (zeroconf-ServiceBrowser__googlecast._tcp.local._162) [pychromecast.discovery] add_service _googlecast._tcp.local., Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6._googlecast._tcp.local.
2020-12-22 09:33:28 DEBUG (zeroconf-ServiceBrowser__googlecast._tcp.local._162) [homeassistant.components.cast.discovery] Discovered chromecast ChromecastInfo(services={'Google-Home-Mini-0ffe556ae1d3fd6825c8aeaefe122bb6._googlecast._tcp.local.'}, host='10.10.xx.177', port=8009, uuid='0ffe556a-e1d3-fd68-25c8-aeaefe122bb6', model_name='Google Home Mini', friendly_name='Biuro')
2020-12-22 09:33:28 DEBUG (zeroconf-ServiceBrowser__googlecast._tcp.local._162) [pychromecast.discovery] add_service _googlecast._tcp.local., Google-Cast-Group-b2b239a0a618412a9597bec5e10eacb9-1._googlecast._tcp.local.
2020-12-22 09:33:30 DEBUG (Thread-7) [homeassistant.components.cast.media_player] [media_player.biuro Biuro] Received cast device connection status: CONNECTED
2020-12-22 09:33:30 DEBUG (Thread-7) [homeassistant.components.cast.media_player] [media_player.biuro Biuro] Cast device availability changed: CONNECTED
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.controllers] Receiver:Updating status
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Sending: Message urn:x-cast:com.google.cast.tp.connection from sender-0 to receiver-0: {'type': 'CONNECT', 'origin': {}, 'userAgent': 'PyChromecast', 'senderInfo': {'sdkType': 2, 'version': '15.605.1.3', 'browserVersion': '44.0.2403.30', 'platform': 4, 'systemVersion': 'Macintosh; Intel Mac OS X10_10_3', 'connectionType': 1}}
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Sending: Message urn:x-cast:com.google.cast.receiver from sender-0 to receiver-0: {'type': 'GET_STATUS', 'requestId': 1}
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Connected!
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.socket_client] Thread started...
2020-12-22 09:33:30 DEBUG (Thread-8) [pychromecast.socket_client] [All(10.10.xx.177):32219] connection listener: 7f73b676a0 (CastStatusListener) ConnectionStatus(status='CONNECTED', address=NetworkAddress(address='10.10.xx.177', port=32219))
2020-12-22 09:33:30 DEBUG (Thread-8) [homeassistant.components.cast.media_player] [media_player.all All] Received cast device connection status: CONNECTED
2020-12-22 09:33:30 DEBUG (Thread-8) [homeassistant.components.cast.media_player] [media_player.all All] Cast device availability changed: CONNECTED
2020-12-22 09:33:30 DEBUG (Thread-8) [pychromecast.controllers] Receiver:Updating status
2020-12-22 09:33:30 DEBUG (Thread-8) [pychromecast.socket_client] [All(10.10.xx.177):32219] Sending: Message urn:x-cast:com.google.cast.receiver from sender-0 to receiver-0: {'type': 'GET_STATUS', 'requestId': 2}
2020-12-22 09:33:30 DEBUG (Thread-8) [pychromecast.socket_client] [All(10.10.xx.177):32219] Connected!
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Received: Message urn:x-cast:com.google.cast.media from 1154ad92-d2e0-4d9c-8306-e4f256f7028e to sender-0: {'type': 'MEDIA_STATUS', 'status': [{'mediaSessionId': 1, 'playbackRate': 1, 'playerState': 'PLAYING', 'currentTime': 627.131323, 'supportedMediaCommands': 274445, 'volume': {'level': 1, 'muted': False}, 'activeTrackIds': [], 'media': {'contentId': 'http://195.150.20.246/rmf_fm', 'streamType': 'LIVE', 'mediaCategory': 'AUDIO', 'contentType': 'audio/mpeg', 'metadata': {'metadataType': 3, 'title': 'Najlepsza Muzyka / The Best Music', 'artist': 'Radio RMF FM', 'images': [{'url': 'https://cdn-profiles.tunein.com/s1217/images/logoq.png?t=636353'}], 'subtitle': 'Radio RMF FM'}, 'duration': None, 'tracks': [{'trackId': 1, 'type': 'AUDIO'}], 'customData': {'title': 'Radio RMF FM', 'subtitle': 'Najlepsza Muzyka / The Best Music', 'castUiTitle': 'Najlepsza Muzyka / The Best Music', 'castUiSubtitle': 'Radio RMF FM', 'image': 'https://cdn-profiles.tunein.com/s1217/images/logoq.png?t=636353', 'primaryGuideId': 's1217', 'secondaryGuideId': '', 'followOptions': [{'title': 'Favorite Station', 'guideId': 's1217', 'isFollowing': False, 'url': 'http://opml.radiotime.com/favorites.ashx?c=add&id=s1217&formats=mp3,aac,ogg,wav,hls&partnerId=NVok3txQ&serial=848da04a-3ad0-425a-b8ff-5ca6653b8cbd&version=1.18&itemToken=BgwMAAAAAAAAAAAAAAABwQQAAAEMAcEEAAABwQQAAA'}], 'ads': {'canShowAds': True, 'canShowPrerollAds': True, 'canShowCompanionAds': False, 'canShowVideoPrerollAds': False}, 'classification': {'contentType': 'music', 'isEvent': False, 'isOnDemand': False, 'isFamilyContent': False, 'isMatureContent': False, 'genreId': 'g3'}, 'ttl': 17000, 'share': {'canShare': True, 'shareUrl': 'http://tun.in/sejpH'}, 'isStation': True, 'isProgram': False, 'isTopic': False, 'contentId': 's1217'}, 'breaks': [], 'breakClips': []}, 'currentItemId': 1, 'items': [{'itemId': 1, 'media': {'contentId': '', 'streamType': 'NONE', 'contentType': '', 'duration': None}, 'autoplay': False, 'customData': {'guideId': 's1217', 'serial': '848da04a-3ad0-425a-b8ff-5ca6653b8cbd', 'version': 1.18, 'partnerId': 'NVok3txQ'}, 'orderId': 0}], 'repeatMode': 'REPEAT_OFF'}], 'requestId': 3}
2020-12-22 09:33:30 DEBUG (Thread-7) [pychromecast.controllers] Media:Received status {'type': 'MEDIA_STATUS', 'status': [{'mediaSessionId': 1, 'playbackRate': 1, 'playerState': 'PLAYING', 'currentTime': 627.131323, 'supportedMediaCommands': 274445, 'volume': {'level': 1, 'muted': False}, 'activeTrackIds': [], 'media': {'contentId': 'http://195.150.20.246/rmf_fm', 'streamType': 'LIVE', 'mediaCategory': 'AUDIO', 'contentType': 'audio/mpeg', 'metadata': {'metadataType': 3, 'title': 'Najlepsza Muzyka / The Best Music', 'artist': 'Radio RMF FM', 'images': [{'url': 'https://cdn-profiles.tunein.com/s1217/images/logoq.png?t=636353'}], 'subtitle': 'Radio RMF FM'}, 'duration': None, 'tracks': [{'trackId': 1, 'type': 'AUDIO'}], 'customData': {'title': 'Radio RMF FM', 'subtitle': 'Najlepsza Muzyka / The Best Music', 'castUiTitle': 'Najlepsza Muzyka / The Best Music', 'castUiSubtitle': 'Radio RMF FM', 'image': 'https://cdn-profiles.tunein.com/s1217/images/logoq.png?t=636353', 'primaryGuideId': 's1217', 'secondaryGuideId': '', 'followOptions': [{'title': 'Favorite Station', 'guideId': 's1217', 'isFollowing': False, 'url': 'http://opml.radiotime.com/favorites.ashx?c=add&id=s1217&formats=mp3,aac,ogg,wav,hls&partnerId=NVok3txQ&serial=848da04a-3ad0-425a-b8ff-5ca6653b8cbd&version=1.18&itemToken=BgwMAAAAAAAAAAAAAAABwQQAAAEMAcEEAAABwQQAAA'}], 'ads': {'canShowAds': True, 'canShowPrerollAds': True, 'canShowCompanionAds': False, 'canShowVideoPrerollAds': False}, 'classification': {'contentType': 'music', 'isEvent': False, 'isOnDemand': False, 'isFamilyContent': False, 'isMatureContent': False, 'genreId': 'g3'}, 'ttl': 17000, 'share': {'canShare': True, 'shareUrl': 'http://tun.in/sejpH'}, 'isStation': True, 'isProgram': False, 'isTopic': False, 'contentId': 's1217'}, 'breaks': [], 'breakClips': []}, 'currentItemId': 1, 'items': [{'itemId': 1, 'media': {'contentId': '', 'streamType': 'NONE', 'contentType': '', 'duration': None}, 'autoplay': False, 'customData': {'guideId': 's1217', 'serial': '848da04a-3ad0-425a-b8ff-5ca6653b8cbd', 'version': 1.18, 'partnerId': 'NVok3txQ'}, 'orderId': 0}], 'repeatMode': 'REPEAT_OFF'}], 'requestId': 3}
2020-12-22 09:33:34 DEBUG (zeroconf-Engine-157) [zeroconf] Received from '10.10.xx.176':5353 (socket 7): <DNSIncoming:{id=0, flags=0, n_q=1, n_ans=0, n_auth=0, n_add=0, questions=[question[a,in,wpad.local.]], answers=[]}> (28 bytes) as [b'\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x04wpad\x05local\x00\x00\x01\x00\x01']
2020-12-22 09:33:34 DEBUG (zeroconf-Engine-157) [zeroconf] Ignoring duplicate message received from '10.10.xx.176':5353 (socket 7) (28 bytes) as [b'\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x04wpad\x05local\x00\x00\x01\x00\x01']
2020-12-22 09:33:34 DEBUG (zeroconf-Engine-157) [zeroconf] Ignoring duplicate message received from '10.10.xx.174':5353 (socket 7) (28 bytes) as [b'\x00\x00\x00\x00\x00\x01\x00\x00\x00\x00\x00\x00\x04wpad\x05local\x00\x00\x01\x00\x01']
2020-12-22 10:07:42 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:07:44 DEBUG (Thread-8) [pychromecast.socket_client] [All(10.10.xx.177):32219] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:07:47 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:19:05 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:19:07 DEBUG (Thread-8) [pychromecast.socket_client] [All(10.10.xx.177):32219] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:19:10 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:19:12 DEBUG (Thread-8) [pychromecast.socket_client] [All(10.10.xx.177):32219] Not connected, sleeping for 5.0s. Services: set()
2020-12-22 10:19:15 DEBUG (Thread-7) [pychromecast.socket_client] [Biuro(10.10.xx.177):8009] Not connected, sleeping for 5.0s. Services: set()
Any ideawhat to do, what to check?
Wojtek
