HA Doesn't start properly on my QNAP Container Station
Hi There, I have used the following link; Alternative - Home Assistant
to install HA on my Docker App on my QNAP NAS but the container exits after a few seconds after launch.
Would anyone have an idea ?
Here is the log.
Many thanks to the ones who could help.
Laurent
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
: Unsupported system page size
Fatal Python error: _PyRuntimeState_Init_impl: memory allocation failed
Python runtime state: unknown
[18:46:44] INFO: Home Assistant Core finish process exit code 1
[18:46:44] INFO: Home Assistant Core service shutdown
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-svwait: fatal: unable to s6_svstatus_read: No such file or directory
services-up: warning: some legacy longruns failed to start
s6-rc: warning: unable to start service legacy-services: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
[18:49:49] INFO: Home Assistant Core finish process exit code 1
[18:49:49] INFO: Home Assistant Core service shutdown
