Hi Team,
It’s my first time playing around with HA, but I trying to control my ceiling lights with it.
I’ve Home Assistant 0.102.3; Raspberry Pi 4 4Gb with Raspbian Lite; and 5 YeeLight ceiling lights with last firmware and with the LAN option activated on the app. Its a pretty fresh install…
But, unfortunately the YeeLight Ceiling Lights are not showing in HA.
This is my conf file:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
discovery:
ignore:
- yeelight
yeelight: !include yeelight.yaml
And my yeelight.yaml file:
devices:
192.168.1.151:
model: ceiling3
save_on_change: true
192.168.1.152:
model: ceiling3
192.168.1.153:
name: Master Suite Ceiling
model: ceiling3
192.168.1.154:
name: Guest Room Ceiling
model: ceiling3
192.168.1.155:
model: ceiling3
I’ve used the info about the integration of Yeelight and also the changes from this topic, but no success.
Can someone help and explain what I’m doing wrong and why I can’t see the devices in HA?
Thanks a lot!
