HA Entity node no output when using msg.enable
I’m using the HA entity node which outputs when switched from within HA.
I was testing a flow sending msg.enable=true which does turn on the switch but it produces no output, is this normal?
Output on state change is turned on.
Hi !
Node doc says : image
So I guess it is what it is !
I read the blurb but sometimes others have come up with solutions. Thx!
