I’m trying to display numeric HA entities on a display connected to an esphome device. Display works, but it shows up as nan. This is a re-used ESP module and after having a huge amount of trouble getting the encryption key changed, which is a whole other topic and seems to be a recurring one, now it indicates that the HA API is indeed connecting. This seems to be the main issue people are having when this happens, but this is not the case here. Right now encryption is disabled for testing purposes. When polling the entity state, i’m guessing this should show up in the log? It does not.
Config:
esphome:
friendly_name: LCD-5110-1
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "[redacted]"
spi:
clk_pin: D5
mosi_pin: D7
font:
- file: 'Arial.ttf'
- platform: homeassistant
name: "PV production"
entity_id: sensor.pv_output_pwr_lo
internal: true
attribute: state
state_class: measurement
accuracy_decimals: 3
unit_of_measurement: "kW"
display:
- platform: pcd8544
reset_pin: D0
cs_pin: D8
dc_pin: D1
contrast: 50
lambda: |-
it.printf(0, 0, id(font1), "PV: %.3fkW", id(pv_production).state);
wifi:
ssid: !secret wifi_ssid
manual_ip:
# Set this to the IP of the ESP
static_ip: 172.17.32.201
# Set this to the IP address of the router. Often ends with .1
gateway: 172.17.32.253
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
ap:
ssid: "Lcd-5110-1 Fallback Hotspot"
captive_portal:
Log output from ESP device:
INFO ESPHome 2023.8.2
INFO Reading configuration /config/esphome/lcd-5110-1.yaml...
INFO Starting log output from 172.17.32.201 using esphome API
INFO Successfully connected to 172.17.32.201
[08:16:31][I][app:102]: ESPHome version 2023.8.2 compiled on Sep 5 2023, 08:13:34
[08:16:31][C][wifi:543]: WiFi:
[08:16:31][C][wifi:379]: Local MAC: C8:C9:A3:06:4A:D4
[08:16:31][C][wifi:380]: SSID: [redacted]
[08:16:31][C][wifi:381]: IP Address: 172.17.32.201
[08:16:31][C][wifi:382]: BSSID: [redacted]
[08:16:31][C][wifi:384]: Hostname: 'lcd-5110-1'
[08:16:31][C][wifi:386]: Signal strength: -78 dB ▂▄▆█
[08:16:31][C][wifi:390]: Channel: 1
[08:16:31][C][wifi:391]: Subnet: 255.255.255.0
[08:16:31][C][wifi:392]: Gateway: 172.17.32.253
[08:16:31][C][wifi:393]: DNS1: 0.0.0.0
[08:16:31][C][wifi:394]: DNS2: 0.0.0.0
[08:16:31][C][logger:301]: Logger:
[08:16:31][C][logger:302]: Level: DEBUG
[08:16:31][C][logger:303]: Log Baud Rate: 115200
[08:16:31][C][logger:305]: Hardware UART: UART0
[08:16:32][C][spi:125]: SPI bus:
[08:16:32][C][spi:126]: CLK Pin: GPIO14
[08:16:32][C][spi:128]: MOSI Pin: GPIO13
[08:16:32][C][spi:130]: Using HW SPI: YES
[08:16:32][C][pcd_8544:102]: PCD8544
[08:16:32][C][pcd_8544:102]: Rotations: 0 °
[08:16:32][C][pcd_8544:102]: Dimensions: 84px x 48px
[08:16:32][C][pcd_8544:103]: DC Pin: GPIO5
[08:16:32][C][pcd_8544:104]: Reset Pin: GPIO16
[08:16:32][C][pcd_8544:105]: Update Interval: 1.0s
[08:16:32][C][captive_portal:088]: Captive Portal:
[08:16:32][C][mdns:112]: mDNS:
[08:16:32][C][mdns:113]: Hostname: lcd-5110-1
[08:16:32][C][ota:093]: Over-The-Air Updates:
[08:16:32][C][ota:094]: Address: 172.17.32.201:8266
[08:16:32][C][ota:097]: Using Password.
[08:16:32][C][api:138]: API Server:
[08:16:32][C][api:139]: Address: 172.17.32.201:6053
[08:16:32][C][api:143]: Using noise encryption: NO
[08:16:32][C][homeassistant.sensor:030]: Homeassistant Sensor 'PV production'
[08:16:32][C][homeassistant.sensor:030]: State Class: 'measurement'
[08:16:32][C][homeassistant.sensor:030]: Unit of Measurement: 'kW'
[08:16:32][C][homeassistant.sensor:030]: Accuracy Decimals: 3
[08:16:32][C][homeassistant.sensor:031]: Entity ID: 'sensor.pv_output_pwr_lo'
[08:16:32][C][homeassistant.sensor:033]: Attribute: 'state'
[08:16:34][D][api:102]: Accepted 172.17.32.200
[08:16:34][D][api.connection:1031]: Home Assistant 2023.8.4 (172.17.32.200): Connected successfully
