I’m new to Home-assistant, just installed the Green HA last few days, work well until yesterday, but today all the switches doesn’t work below error message appear:
Restart once, it worked for few mins, and failed again.
Below are the log report, appreciate some help how to resolve this issue:
Logger:
homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:239
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 11:04:38 (8 occurrences)
Last logged: 11:21:09
[281472917809344] Failed to send request: Failed to enqueue message after 3 attempts: <EmberStatus.MAX_MESSAGE_LIMIT_REACHED: 114>
[281472562912064] Failed to send request: Failed to enqueue message after 3 attempts: <EmberStatus.MAX_MESSAGE_LIMIT_REACHED: 114>
[281472558725056] Failed to send request: Failed to enqueue message after 3 attempts: <EmberStatus.MAX_MESSAGE_LIMIT_REACHED: 114>
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 64, in wrap_zigpy_exceptions
yield
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 84, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File “/usr/local/lib/python3.12/site-packages/zigpy/util.py”, line 131, in retry
return await func()
File “/usr/local/lib/python3.12/site-packages/zigpy/quirks/init.py”, line 228, in command
return await self.request(
File “/usr/local/lib/python3.12/site-packages/zigpy/zcl/init.py”, line 377, in request
return await self._endpoint.request(
File “/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py”, line 253, in request
return await self.device.request(
File “/usr/local/lib/python3.12/site-packages/zigpy/device.py”, line 339, in request
await send_request()
File “/usr/local/lib/python3.12/site-packages/zigpy/application.py”, line 841, in request
await self.send_packet(
File “/usr/local/lib/python3.12/site-packages/bellows/zigbee/application.py”, line 912, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to enqueue message after 3 attempts: <EmberStatus.MAX_MESSAGE_LIMIT_REACHED: 114>
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 239, in handle_call_service
response = await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 2543, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2580, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 971, in entity_service_call
single_response = await _handle_entity_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1043, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/light/init.py”, line 642, in async_handle_light_off_service
await light.async_turn_off(**filter_turn_off_params(light, params))
File “/usr/src/homeassistant/homeassistant/components/zha/light.py”, line 472, in async_turn_off
result = await self._on_off_cluster_handler.off()
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 83, in wrapper
with wrap_zigpy_exceptions():
File “/usr/local/lib/python3.12/contextlib.py”, line 158, in exit
self.gen.throw(value)
File “/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/init.py”, line 75, in wrap_zigpy_exceptions
raise HomeAssistantError(message) from exc
homeassistant.exceptions.HomeAssistantError: Failed to send request: Failed to enqueue message after 3 attempts: <EmberStatus.MAX_MESSAGE_LIMIT_REACHED: 114>
Thanks guys
