Ha esp32 fan control problem
Hi guys.
New here.
i have spent way too much time on this and i am stuck.
i am trying to control 4 fans speed depending on temperature. the higher the temperature difference the faster the fans spin. . My problem is that she fan relay "fan_power doesnt switch on when the temperature is high. do you have any ideas on what am i doing wrong? i have checked the code in yaml checker and it removed all the comments. also i am reverse engineering this from another project.
substitutions:
  name: MPPT Chladenie
  max_temp: "50"
  dallas_addr: "0xff455bd443c84d28"
  dallas_addr1: "0xda605ed4436a9b28"
  dallas_addr2: "0x1524b3d443e83b28"
  dallas_addr3: "0x6269b8d443293b28"
esphome:
  friendly_name: Ventilatory Victron chladenie
esp32:
  board: esp32dev
  framework:
    type: arduino
logger:
  logs:
    dallas sensor: none
    number: none
    sensor: none
    light: none
    fan: none
api:
  encryption:
    key: 5s92kG9kX5565gsNWUDuyaSC/rXfGRMhiXiU2iTDt2Y=
ota:
  - platform: esphome
    password: 0f5e0bc8334cc7fa09a63e95aba05905
wifi:
  manual_ip:
    static_ip: 192.168.1.111
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ssid: !secret wifi_ssid
  ap:
    ssid: Ventilatory-Victron-Chladenie
    password: kncRpVx4GlOn
captive_portal: null
number:
    name: MPPT 250/100 Nast. Tepl.
    optimistic: true
    min_value: 10
    max_value: 50
    initial_value: 25
    step: 1
    restore_value: true
    name: MPPT 250/85 Nast. Tepl.
    optimistic: true
    min_value: 10
    max_value: 50
    initial_value: 25
    step: 1
    restore_value: true
    name: multiplus L1 Nast. Tepl.
    optimistic: true
    min_value: 10
    max_value: 50
    initial_value: 25
    step: 1
    restore_value: true
    name: Multiplus L2 Nast. Tepl.
    optimistic: true
    min_value: 10
    max_value: 50
    initial_value: 25
    step: 1
    restore_value: true
one_wire:
  - platform: gpio
    pin: GPIO17
  - platform: dallas_temp
    address: $dallas_addr
    name: MPPT 250/100 Teplota
    update_interval: 2s
    accuracy_decimals: 0
    address: $dallas_addr1
    name: MPPT 250/85 Teplota
    update_interval: 2s
    address: $dallas_addr2
    name: Multiplus L1 Teplota
    update_interval: 2s
    address: $dallas_addr3
    name: Multiplus L2 Teplota
    update_interval: 2s
    # Adjust fan speed(1-100%). Else, turn it off and set the speed to 1
    on_value:
      - lambda: !lambda |
          auto pct = map(x, id(set_temp).state, id(set_temp).state+20, 1, 100);
          if (pct>1) {
            auto call = id(the_fan).turn_on(); call.set_speed(pct); call.perform();
          } else {
            auto call = id(the_fan).turn_off(); call.set_speed(1); call.perform();
      - lambda: !lambda |
          auto pct = map(x, id(set_temp1).state, id(set_temp1).state+20, 1, 100);
          if (pct>1) {
            auto call = id(the_fan1).turn_on(); call.set_speed(pct); call.perform();
          } else {
            auto call = id(the_fan1).turn_off(); call.set_speed(1); call.perform();
      - lambda: !lambda |
          auto pct = map(x, id(set_temp2).state, id(set_temp2).state+20, 1, 100);
          if (pct>1) {
            auto call = id(the_fan2).turn_on(); call.set_speed(pct); call.perform();
          } else {
            auto call = id(the_fan2).turn_off(); call.set_speed(1); call.perform();
      - lambda: !lambda |
          auto pct = map(x, id(set_temp3).state, id(set_temp3).state+20, 1, 100);
          if (pct>1) {
            auto call = id(the_fan3).turn_on(); call.set_speed(pct); call.perform();
          } else {
            auto call = id(the_fan3).turn_off(); call.set_speed(1); call.perform();
      - if:
          condition:
            for:
              time: 5s
              condition:
                lambda: return id(temp_sensor).state > id(set_temp).state+20;
          then:
            - light.turn_on:
                effect: flashfast
            - lambda: id(alarm1).publish_state(true);
          else:
            - light.turn_off: d4_light
            - lambda: id(alarm1).publish_state(false);
      - if:
          condition:
            for:
              time: 5s
              condition:
                lambda: return id(temp_sensor1).state > id(set_temp1).state+20;
          then:
            - light.turn_on:
                effect: flashfast
            - lambda: id(alarm2).publish_state(true);
          else:
            - lambda: id(alarm2).publish_state(false);
      - if:
          condition:
            for:
              time: 5s
              condition:
                lambda: return id(temp_sensor2).state > id(set_temp2).state+20;
          then:
            - light.turn_on:
                effect: flashfast
            - lambda: id(alarm3).publish_state(true);
          else:
            - lambda: id(alarm3).publish_state(false);
      - if:
          condition:
            for:
              time: 5s
              condition:
                lambda: return id(temp_sensor3).state > id(set_temp3).state+20;
          then:
            - light.turn_on:
                effect: flashfast
            - lambda: id(alarm4).publish_state(true);
          else:
            - lambda: "id(alarm4).publish_state(false);                                "
switch:
  - platform: gpio
    pin: GPIO5
    inverted: true
  - platform: gpio
    pin: GPIO18
    inverted: True
  - platform: gpio
    pin: GPIO19
    inverted: true
  - platform: gpio
    pin: GPIO21
    inverted: true
fan:
  - platform: speed
    output: fan_pwm
    name: MPPT 250/100 Ventilator
    speed_count: 100
    on_turn_on:
      - switch.turn_on: fan_power
    on_turn_off:
      - switch.turn_off: fan_power
  - platform: speed
    output: fan_pwm1
    name: MPPT 250/85 Ventilator
    speed_count: 100
    on_turn_on:
      - switch.turn_on: fan_power1
    on_turn_off:
      - switch.turn_off: fan_power1
  - platform: speed
    output: fan_pwm2
    name: Multiplus L1 Ventilator
    speed_count: 100
    on_turn_on:
      - switch.turn_on: fan_power2
    on_turn_off:
      - switch.turn_off: fan_power2
  - platform: speed
    output: fan_pwm3
    name: Multiplus L2 Ventilator
    speed_count: 100
    on_turn_on:
      - switch.turn_on: fan_power3
    on_turn_off:
      - switch.turn_off: fan_power3
binary_sensor:
    name: Alarm mppt 250/100
    icon: mdi:fire
    name: Alarm mppt250/85
    icon: mdi:fire
    name: Alarm Multiplus L1
    icon: mdi:fire
    name: Alarm Multiplus L2
    icon: mdi:fire
light:
  - platform: monochromatic
    output: d4_light_pwm
    effects:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
output:
  - platform: ledc
    pin:
      number: GPIO13
    min_power: 0.05
    frequency: 25.0kHz
  - platform: ledc
    pin:
      number: GPIO12
    min_power: 0.05
    frequency: 25.0kHz
  - platform: ledc
    pin:
      number: GPIO14
    min_power: 0.05
    frequency: 25.0kHz
  - platform: ledc
    pin:
      number: GPIO27
    min_power: 0.05
    frequency: 25.0kHz
  - platform: slow_pwm
    period:
      seconds: 1
    pin:
      number: GPIO2
      inverted: true
type or paste code here
What you mean with this? Just fan_power doesn’t or any of them (3) don’t?
Also, your code switches fan_power on only when you switch speed fan on.
Maybe this will help.
i have a set temperature when the fan should start spinning and when the pwm starts to control the fan the ralay sill switch on to put power to the fan. but now what happens is the fan doesnt turn on when the temperature reaches the treshold. it will only turn on when i manually move the slider for the temperature settings. hope this helps.
You didn’t answer my first question, just fan_power or all of them?
Also be aware that you have automations only for temp_sensor3.
Sorry for late reply.
I have scrapped the whole thing and created it again with correct formatting. now it works perfectly.
thank you for your help.
