HA + EspHome = WS2812B stairs project - delay error
Hello All,
I’ve combined a small project including HA, EspHome, WS2812B Led strips and Aqara motion sensors to light my 14step stairs. Everything work good except lightning each step that is taking 1second. Cant make it like 400ms. Below is my code, I know it’s chaotic but it works.
My automation:
- id: '15857734476143'
  alias: Sch_down
  description: swiatła dół góra
  - entity_id: binary_sensor.0x00158d0004058359_occupancy
    platform: state
    to: 'on'
  condition:
    - condition: state
      entity_id: input_boolean.notify_schody_up
      state: 'off'
    - condition: state
      entity_id: input_boolean.notify_schody_down
      state: 'off'
    - condition: time
      after: '19:00:00'
      before: '07:00:00'
  - service: light.turn_on
    entity_id: light.step14
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step13
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step12
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step11
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step10
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step9
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step8
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step7
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step6
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step5
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step4
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step3
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
    entity_id: light.step2
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
  - delay:
      milliseconds: 100
      brightness: 60
      rgb_color:
      - 120
      - 0
      - 0
Congiguration on EspHome is making how many leds are on each step.
While the documents say that milliseconds are valid (and they are) they don’t tell you that the minimum possible delay resolution is 1 second (1000ms). It’s just the way home assistant works.
Hmmm in that way i will be faster on top of the stairs than the light.
Maybe other solution for it like Lambdas in EspHome? But this is black magic for me…
I’m pretty sure ESPHome can do sub 1sec delays.
I don’t know what your esphome.yaml looks like, but maybe you could work with a Template Switch inside ESPHome and then do the automation for the lights in there.
Something like this (just a rough example to get the idea):
# Example configuration entry
substitutions:
  delay_value: 100ms
switch:
    name: "Template Switch (schody_down)"
    turn_on_action:
      - light.turn_on: step14
      - delay: ${delay_value}
      - light.turn_on: step13
      - light.turn_on: step12
So in a simple way it could work without lambdas…
My configuration.yaml on EspHome looks like this:
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO2
    num_leds: 420
    rgb_order: BRG
  - platform: partition
    segments:
      - id: stairs
        to: 29
    segments:
      - id: stairs
        to: 59
    segments:
      - id: stairs
        to: 89
    segments:
      - id: stairs
        to: 119
    segments:
      - id: stairs
        to: 149
    segments:
      - id: stairs
        to: 179
    segments:
      - id: stairs
        to: 209
    segments:
      - id: stairs
        to: 239
    segments:
      - id: stairs
        to: 269
    segments:
      - id: stairs
        to: 299
    segments:
      - id: stairs
        to: 329
    segments:
      - id: stairs
        to: 359
    segments:
      - id: stairs
        to: 389
    segments:
      - id: stairs
        to: 429
switch:
    turn_on_action:
      - light.turn_on:
          brightness: 20%
          red: 100%
          green: 100%
          blue: 0%
      - delay: 500ms
      - light.turn_on:
          brightness: 20%
          red: 100%
          green: 100%
          blue: 0%
And the switch does nothing… I can light any step from Home Assistant but using EspHome cant do anything… Really need help
In addition i recive in log:
WARNING Disconnected from API: Timeout while waiting for message response!
INFO Connecting to schody.local:6053 (192.168.0.135)
INFO Successfully connected to schody.local
[18:12:58][D][api.connection:583]: Client 'Home Assistant 0.107.7 (192.168.0.114)' connected successfully!
