My second problem concerns the address to use to get the *.ics file:
https:///api/calendars/{entity_id}/export.ics
: is this the IP address of HA?
{entity_id}: the identity ID that I will find in parameter… in my case calendar.test?
My questions may seem strange to you, but you get it, I’m a beginner
Since you are new to YAML you might want to put it somewhere that isn’t labelled as the place for the “default set of integrations”. I would suggest adding a new comment for custom integrations to keep everything organized:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
# Load custom integrations added by user
calendar_export:
That should be done automatically if you did the above section correctly and restart HA. When you go to the Integrations page, you should see Calendar Export in the list…
Indeed, good advice, I risk getting lost afterwards
Concerning integration, I have “Calendar Export” in the section. As shown in your capture. So a priori, it’s good, nothing more to do in terms of configuration?
I will start the procedure again taking into account your remarks.
Ok! I manage to recover the exported *.ics file (I admit I don’t really know why it worked after the reinstallation) but I have another problem, the recovered *ics file does not have a UID/event and I end up with the last event of each export without the rest since they are all recognized as duplicates… does anyone have a solution to counter the problem?
