yesterday HA works normally. Today in the morning I wanted to open my HA app, nothing happens.
So I checked at my PC with browser. Same result.
Then I’ve checked the logs in /var/snap/home-assistant/current/home-assistant.log
The entries are:
2021-11-06 09:20:56 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration goecharger which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-11-06 09:20:56 ERROR (MainThread) [homeassistant.loader] Unable to resolve dependencies for default_config: we are unable to resolve (sub)dependency updater
Reboot doesnt work. I’ve also disabled the custom integration goecharger in my configuration.yaml but the message still appears in logfile. I think the problem is the “unable to resolve dependency updater”.
I’M using home-assistant core.
Any ideas what I have to do to repair this? Thanks a lot!
Thank you francips! Now it’s starting. But how can I check whats the problem with updater component? I’ve changed nothing. What is the cause for this behavior?
I ran into some other failures after this and do a complete fresh install.
I’ve used ESXi and the HAOS for this. So now I have the ability to use Backups and can use easily addons. Its a better solution as snaps.
