HA fails to connect to MariaDB
If I use the MariaDB add-on inside of HA, I’m good, but I’m running HA as a VM in Unraid and I would like HA to use the MariaDB instance that’s already running in Docker on my Unraid box.
So, if I reconfigure the connection to point to the server I want, I get an error in HA, and I get an error on the MariaDB database log. Both are below, but I should note that I am able to connect to the database server I want using MySQL Workbench, so I’m not sure what’s causing it…
Home Assistant:
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:1070
Integration: Recorder (documentation, issues)
First occurred: 8:19:32 PM (10 occurrences)
Last logged: 8:20:44 PM
Error during connection setup: (MySQLdb.OperationalError) (2013, "Lost connection to MySQL server at 'handshake: reading initial communication packet', system error: 104") (Background on this error at: https://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3280, in _wrap_pool_connect
    return fn()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 310, in connect
    return _ConnectionFairy._checkout(self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 868, in _checkout
    fairy = _ConnectionRecord.checkout(pool)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 476, in checkout
    rec = pool._do_get()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 145, in _do_get
    with util.safe_reraise():
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/langhelpers.py", line 70, in __exit__
    compat.raise_(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/util/compat.py", line 208, in raise_
    raise exception
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/impl.py", line 143, in _do_get
    return self._create_connection()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 256, in _create_connection
    return _ConnectionRecord(self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 371, in __init__
    self.__connect()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 665, in __connect
    compat.raise_(
    raise exception
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/pool/base.py", line 661, in __connect
    self.dbapi_connection = connection = pool._invoke_creator(self)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/create.py", line 590, in connect
    return dialect.connect(*cargs, **cparams)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/default.py", line 597, in connect
    return self.dbapi.connect(*cargs, **cparams)
  File "/usr/local/lib/python3.10/site-packages/MySQLdb/__init__.py", line 123, in Connect
    return Connection(*args, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/MySQLdb/connections.py", line 185, in __init__
    super().__init__(*args, **kwargs2)
MySQLdb.OperationalError: (2013, "Lost connection to MySQL server at 'handshake: reading initial communication packet', system error: 104")
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 630, in _setup_recorder
    self._setup_connection()
  File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 1070, in _setup_connection
    Base.metadata.create_all(self.engine)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/sql/schema.py", line 4916, in create_all
    bind._run_ddl_visitor(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 341, in _run_ddl_visitor
    with self.begin() as conn:
  File "/usr/local/lib/python3.10/contextlib.py", line 135, in __enter__
    return next(self.gen)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 379, in begin
    with self.connect() as conn:
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/future/engine.py", line 406, in connect
    return super(Engine, self).connect()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3234, in connect
    return self._connection_cls(self, close_with_result=close_with_result)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 96, in __init__
    else engine.raw_connection()
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3313, in raw_connection
    return self._wrap_pool_connect(self.pool.connect, _connection)
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 3283, in _wrap_pool_connect
    Connection._handle_dbapi_exception_noconnection(
  File "/usr/local/lib/python3.10/site-packages/sqlalchemy/engine/base.py", line 2117, in _handle_dbapi_exception_noconnection
    util.raise_(
    raise exception
    return fn()
    compat.raise_(
    raise exception
    self.__connect()
    compat.raise_(
    raise exception
sqlalchemy.exc.OperationalError: (MySQLdb.OperationalError) (2013, "Lost connection to MySQL server at 'handshake: reading initial communication packet', system error: 104")
MariaDB:
2022-07-20 20:20:20 21 [Warning] Aborted connection 21 to db: 'unconnected' user: 'unauthenticated' host: 'homeassistant.localdomain' (This connection closed normally without authentication)
please post your db_url entry from your configyaml
