HA failure - help recovering Tasmota integration
Hi All,
After an unrecoverable corruption, I have installed HASSOS new and restored the configuration files which has many things up and running again - except Tasmota which was working perfectly prior to this - all devices on Tasmota 10.0. Process was install HASSOS on new virtual machine - configured so DHCP gave exact same address as the previous 2+ year old debian machine, then restore configuration from backup.
None of the tasmota devices will now connect to HA, I can however get into the tasmota web pages.
I had it all running using ‘native’ discovery rather than mqtt discovery, so I have tried the setoption19 command but made zero progress in two days.
Can anyone help suggest some direction please?
For the mqtt discovery, the solution normally was setoption19 0, then setoption19 1 again. Maybe try the opposite for tasmota discovery
setoption19 1
setoption19 0
Unfortunately the SetOption19 cycle didn’t work
Well I have managed to work my way through this mostly. It seems that 2 days prior when I upgraded my access point I had failed to notice that the tasmota devices were struggling ever since. This is because I changed from a Ubiquiti Unifi AC-Lite to a U6-LongRange.
I had to do the following:
  1. Add the mosquito broker to my new HA instance
  2. Reconfigure it in the integration area so that it had a username configured correctly
    [This fixed the mqtt issues]
    I then had to fix the Tasmota issues.
  3. Apparently Tasmota devices store a “profile” of the wifi network(s) they connect to. I had to purge this profile by getting into the console and using the Tasmota command “RESET 3” this clears out the profile but also requires a power off and power on again after it resets.
  4. In the process of ‘solving’ this problem I also learned about the Tasmota ‘SLEEP’ command, the default sleep setting is 50, in the process of troubleshooting I have now set this to 0 (zero).
Can you see them using mqtt-explorer ?
When they stay connected YES…
But they are no longer reliably connecting
