I have HA loaded in a container on my Synology NAS. I loaded ha-fusion into another container. Now what? How do I get ha-fusion into my Home Assistant?
Sorry, I am very new at containers.
Try here:
Almost 80% of all users use Home Assistant OS. The container installation type is considered by most people to be for experienced users only, who know their way around containers. Most guides assume HAOS because it is most used and also the easiest one to operate. I see Synology also allows to run HAOS in a VM. If you are just starting out and not familiar with installing and maintaining containers, It might be wise to switch to that.
Containers are not that hard to use.
Maybe in beginning but not something that average person cant overcome.
Try to figure out your ha ip and go to your_ha_p:8123
I’ve got the HA container running fine. I also figured out (it took a while) how load the docker compose for ha-fusion. What i can’t find any information on is how to get HA to use ha-fusion. I thought about VM, but I wanted to see if I could do the container.
