i configured an esp with esphome and sensors and led’s. He only talks to the HA via mqtt. In my HA==> mosquitto-device-config I can see the 5 entities. 2 are in the status “ok” and 3 “not available”. However, I can use all 5 with node-red. I almost think it’s just the respective esphome entry name:
my esphome code section DHT22 (state is ok, and i get now connection-error in HA
# DHT22 Temp/Humidy Sensor
- platform: dht
pin: D0
model: AM2302
update_interval: 30s
temperature:
state_topic: AnzuchtBox/DHT22/Temperatur/state
at the same esp there
my LED section ( i get the conection-error in HA State)
light:
- platform: monochromatic
name: "AnzuchtBox 3500K Mitte"
output: "PWM0"
# Optional variables:
retain: false
discovery: true
availability:
topic: AnzuchtBox/3500K_LedMitteOnline
payload_available: online
payload_not_available: offline
state_topic: AnzuchtBox/3500K_LED_Mitte/state
command_topic: AnzuchtBox/3500K_LED_Mitte/command
command_retain: false
i see only one different
my spelling
to
name: “AnzuchtBox 3500K Mitte”
is that possible HA don’t like spaces and like only a-z,A-Z,_,- ?
best regards
Achim
edit:
at the esphome code above i use for pwm a pca9685 multiplexer !
i change now the section in my esphome code to try what’s happen if i change it
name: "Anzuchtbox-5000K" # bevore "Anzuchtbox 5000K" with a space
output: "PWM2"
retain: false
discovery: true
availability:
topic: AnzuchtBox/5000K_LedOnline
state_topic: AnzuchtBox/5000K/state
command_topic: AnzuchtBox/5000K/command
if i delete the entities in the mqtt device
then i get now 1 error there more
i wonder… because the DHT-section there and the entity “Temperatur” and “Luftfeuchtigkeit” show all ok…
i don’t understood why, because in node-red if i try to switch off/on the light… works very well…
But only the device -manager and the mqtt-entities looks like wrong
why?
he show me now 2 light.anzuchtbox_5000k and light.anzuchtbox_5000k_2 entities_ID
why?
what i do ===>
- i change the name in esphome
- i stop the mqtt device with his entities
- i delete all wrong entitis
- i restart HA
- i activate the device in mqtt
then i get 1 entry entitis_id more but all light entities looks like wrong
