Hello the community ,
i’m a newbie on HA , i’m fluent on zigate and eedomus , and want to try home assitant .
i have bought a green box from nabu casa, and begin to install my zigbbe components without to much trouble .
i have installed hacs , and the GCE rfplayer integration add on . my trouble is the following
if i make thei nstallatoin on my NAs , the GCE Rf player is detected, but have some trouble of power supply
if i make the installation on Green assitant , whatever if i put it directly oin the usb port , or through a power suplied Hub , the green assitant don’t boot anymore, it is as if , he perpetually reboot , the trouble is it seems ( i’m newbie) that it doesn’t create any log .
I need this powerfull Rf player with its parrot mode, and all my oregon weather items, my X2D system , my DIO 1.0 switch , and it will be a big amount of money to change for zigbee or thread/matter item , only because there are compatibilty trouble in between HA and RFplayer, for me it will be a direct return to eedomus . does any one know how to manage this ?
( i’m newby so having the config , the log , yaml script, all this is new for me , and still need to be learned)
thank you for your help in advance
Try a powered USB hub
I change the power supply of the home assitant green , and use the repository test-Rfplayer of doubeldom , and now it works and is stable
so both weak power supply of usb / and compatibility trouble with home assitant green
