I have a new HA Green device.
I also have an Aqara M2 hub with paired and wroking well:
- 2 Thermostat E1
- 1 temperature/humidity sensor
- 1 TVOC sensor
- 1 water leak sensor
The problem is that the last two are not visible/detected in Home Assistant.
I tried to remove the TVOC sensor from the aqara gateway and re-add it.
Then re-scan the gateway from the HA portal.
Also I retried to reboot the Aqara gateway.
Those 2 devices are still invisible. But working fine from the Aqara app.
Any idea what I can do to make them manageable from HA?
