HA Green + EMHASS + AMBER electric + DEYE inverters + 100kWh battery. Australia
Hello Team,
Below is a successful execution of the PV plus Battery Storage system, with Home Assistant as automated manager.
System specs:
7KW PV array, two strings
2 x SUN-8K-SG05LP1-AU DEYE aka SunSynk
105kWh battery array. 21 x 5kWh modules
Home Assistant Green
Load - private house, 2 x EV’s
Grid - connected
Suppliers:
PV - generic install, 7 years old.
SUN-8K-SG05LP1-AU - www.solarwyse.com.au
HA Green - ozsmartthings.com.au
Battery (China) - China made Battery - Energy Storage Systems manufactured in China.
Code:
Home Assistant
EMHASS
SunSynk / DEYE inverter Add-on (multi)
Amber electric (Australia only)
Major thanks to Mark @markpurcell for setting up HA & EMHASS for me. I appreciate the hours you have spent getting it working!
System goals:
Evaluate financial/technical feasibility of energy independence concept, with mid/small PV, on mid/high power consumption house with 2 x EV’s.
More to follow…
Reserved for specs
Reserved for specs 2
Reserved for specs 3
Can you share how you control the DEYE inverter?
I would be interested in that as well.
Good for you it’s working… Why aren’t you sharing how you did it though?
It would save everybody some time.
This is Add-on I use. Just install and fill in inverter configuration. It connects and allows you to control it.
This works with DEYE inverters and SunSynk invertes.
Looks like got logged out and did not get notifications on this thread.
Happy to help with that I can.
Looks great, can you post your automations and template’s. Am about to do the same sort of thing and would save a heap of time.
Cheers
Hi, can you share your automations from HA ?
Sad to see no replies in this topic anymore. If people would share their configurations the steep curve to set up and get EMHASS working would hopefully become more shallow. .
Is there any way I can reach out to @markpurcell ?
Thank you kindly.
Hi, could you please upload the HA automations and templates?
