The dongle and configuration is migrated from PC where it worked just fine.
Log output: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
[10:14:29] INFO: Preparing to start...
[10:14:31] INFO: Socat not enabled
[10:14:36] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-08-11 10:14:46] info: z2m: Logging to console, file (filename: log.log)
[2024-08-11 10:14:46] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown)
[2024-08-11 10:14:46] info: z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-11 10:14:47] warning: zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
[2024-08-11 10:14:57] error: zh:ezsp:uart: --> Error: Error: {"sequence":-1} after 10000ms
[2024-08-11 10:14:57] error: zh:ezsp:ezsp: Connection attempt 1 error: Error: Failure to connect
at SerialDriver.resetForReconnect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:341:19)
at SerialDriver.emit (node:events:517:28)
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:344:22
at Queue.execute (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)
at SerialDriver.openSerialPort (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:106:13)
at SerialDriver.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:61:13)
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:347:17)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:176:13)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:127:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
Zigbee troubleshooting instructs to use udevadm
to check and set write permissions by editing /etc/udev.conf
which is not present in HA Green.
Getting error “udevadm: command not found”
[core-ssh ~]$ ls -1 / dev/serial/by-id
total 0
Urwxrwxrwx 1 root root 13 Jan 25 2024 usb-ITEAD_SONOFF •_Zigbee_3.0_USB_Dongle_Plus_V2_20220818080600-if00 > ../../ttyACMO
[core-ssh ~]$ test -w ../../ttyACM0 && echo success || echo fail
fail
[]$ udevadm info -a -n /dev/ttyACMO | grep 'serial'
bash: udevadm: command not found
This exact configuration and dongle worked fine on a PC.
Alternatively user can be adde to groups tty, uucp, dialout. But it seems like it’s running under root anyway? There’s no homeassistant user. And no commands like usermod.
What can I do to make it work?
Thanks!
