Goodmorning!
I am a new HA user, so please feel free to correct me!
Having an issue with HACS on the Home Assistant, hoping someone may assist.
In short my issue is that HACS is successfully installed but there is no entity called HACS nor device.
As well once HACS is entered, it is blank only showing ‘about’
Can someone please review my process, maybe I made a mistake or there was is an issue with HACS
Starters.
I am running HA Core on my raspberry pi device.
This is the tutorial I followed for the installation of HACS
Installation | HACS
For the installation, I entered my raspberry pi which has Linux installed, entered the terminal and switched from pi user to HA user
as the tutorial stated, I copied this code and pasted into the terminal
wget -q -O - https://install.hacs.xyz | bash -
Once HACS was installed, I entered my Home Assistant, checked the configuration validation (which was valid) and restarted the HA.
Now I tried both ways for configuring the HACS, both did not work
Standard configuration,
Cleared my browser cache and then added HACS through HA- integrations.
I agreed to all 4 terms and I was given a device code and entered it to https://github.com/login/device
I authorized HACS to have access to my GitHub account which was successful
Came back to HA clicked submit and HACS was added as an integration on my HA
However there was no entity nor device named HACS
HACS was added on my sidebar but once you enter it. everything was blank besides there being “about”
there were no ‘integrations’, ‘frontend’, ‘automation’ option.
Legacy Configuration (YAML)
I tried to configure the HACS through YAML
by entering my Github account and making personal access token
All tutorials said to just make the token without checking an boxes or setting an options
Once token was made and copied, I went into my configuration.yaml file through my terminal
and added the token as tutorial stated
hacs:
token: mytoken
Once checking in configuration validation and making sure all code was valid. I continued to restart the HA again.
HACS was not added in the integrations section of HA, if you try to add it, it will say “only one configuration of HACS is allowed”
HACS will be added on the sidebar but once you enter it there will only be the option of ‘about’
there was no ‘integrations’, ‘frontend’, ‘automation’ option
