Hi! I’m new to HA.
I have version 2024.2.1 running in my Kubernetes cluster and I’ve been consistently getting the same behavior. Every day or two I need to restart the node that runs it to get it working again.
My integrations are:
- HACS Daikin Altherma
- Zigbee ZHA
- Shelly
- Legrand with Netatmo (Netatmo)
I disabled HACS and Shelly: The hung took longer to happen, but it hung in the end.
I’m quite stuck with the problem. The node runs with enough memory and CPU (it’s a Rpi4 - 8GB that has nothing more than HA.
This is the log I’ve collected:
Please, help me. I don’t have any clue.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
e[33m2024-02-10 10:38:44.374 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration daikin_altherma which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2024-02-10 10:38:44.424 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2024-02-10 10:38:50.050 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanlye[0m
e[33m2024-02-10 10:38:50.195 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=6 from 2024-02-09 18:11:13.070803)e[0m
e[33m2024-02-10 10:39:09.263 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.e[0m
e[33m2024-02-10 10:39:09.263 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.e[0m
e[33m2024-02-10 10:39:09.263 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.e[0m
e[33m2024-02-10 10:39:09.264 WARNING (MainThread) [homeassistant.setup] Setup of tag is taking over 10 seconds.e[0m
e[33m2024-02-10 10:39:09.264 WARNING (MainThread) [homeassistant.setup] Setup of schedule is taking over 10 seconds.e[0m
e[33m2024-02-10 10:39:28.368 WARNING (MainThread) [homeassistant.components.netatmo] Webhook not registered - https and port 443 is required to register the webhooke[0m
[10:41:54] INFO: e[32mHome Assistant Core finish process exit code 100e[0m
e[33m2024-02-10 10:41:58.095 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration daikin_altherma which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2024-02-10 10:41:58.101 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistante[0m
e[33m2024-02-10 10:42:12.952 WARNING (MainThread) [homeassistant.components.netatmo] Webhook not registered - https and port 443 is required to register the webhooke[0m
e[33m2024-02-10 11:00:00.099 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-10 12:00:00.101 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-10 18:00:00.503 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-10 19:00:00.507 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-10 23:00:00.252 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 00:00:00.256 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 05:00:00.352 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 06:00:00.357 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 11:00:00.097 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 12:00:00.099 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[31m2024-02-11 12:26:38.737 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 350, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 557, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message:
Invalid method encountered:
b'\x03'
^e[0m
e[31m2024-02-11 12:29:11.518 ERROR (MainThread) [aiohttp.server] Error handling request
b'\x03'
^e[0m
e[33m2024-02-11 18:00:00.502 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 19:00:00.505 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[33m2024-02-11 23:00:00.251 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities switch.ventilacion_interruptor are missing or not currently availablee[0m
e[31m2024-02-11 23:37:23.403 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547708917952] Failed to send request: device did not respond
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 330, in request
return await req.result
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 64, in wrap_zigpy_exceptions
yield
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 84, in wrapper
return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/zigpy/util.py", line 131, in retry
return await func()
File "/usr/local/lib/python3.12/site-packages/zigpy/quirks/__init__.py", line 199, in command
return await self.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 377, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 253, in request
return await self.device.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 329, in request
async with asyncio_timeout(timeout):
File "/usr/local/lib/python3.12/asyncio/timeouts.py", line 115, in __aexit__
raise TimeoutError from exc_val
TimeoutError
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 240, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2279, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2316, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 892, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 962, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/zha/switch.py", line 91, in async_turn_on
await self._on_off_cluster_handler.turn_on()
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/general.py", line 446, in turn_on
result = await self.on()
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 83, in wrapper
with wrap_zigpy_exceptions():
File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
self.gen.throw(value)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 66, in wrap_zigpy_exceptions
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Failed to send request: device did not responde[0m
e[31m2024-02-12 03:35:46.129 ERROR (MainThread) [zigpy_znp.uart] Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xE8\xD5\x84'))
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/types/commands.py", line 417, in from_frame
params[param.name], data = param.type.deserialize(data)
File "/usr/local/lib/python3.12/site-packages/zigpy/types/struct.py", line 315, in deserialize
value, data = field_type.deserialize(data)
File "/usr/local/lib/python3.12/site-packages/zigpy/types/basic.py", line 194, in deserialize
raise ValueError(f"Data is too short to contain {byte_size} bytes")
ValueError: Data is too short to contain 1 bytes
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/uart.py", line 73, in data_received
self._api.frame_received(frame.payload)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 840, in frame_received
command = command_cls.from_frame(frame, align=self.nvram.align_structs)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/types/commands.py", line 424, in from_frame
raise ValueError(
ValueError: Frame data is truncated (parsed {'Src': 0xD5E8, 'Status': <Status.NOT_SUPPORTED: 132>}), required parameter remains: Param(name='Routes', type=<class 'zigpy.zdo.types.Routes'>, description='Routes', optional=False)e[0m
e[31m2024-02-12 03:35:47.590 ERROR (MainThread) [zigpy_znp.uart] Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x9A\x0A\x84'))
raise ValueError(
ValueError: Frame data is truncated (parsed {'Src': 0x0A9A, 'Status': <Status.NOT_SUPPORTED: 132>}), required parameter remains: Param(name='Routes', type=<class 'zigpy.zdo.types.Routes'>, description='Routes', optional=False)e[0m
e[31m2024-02-12 03:35:48.931 ERROR (MainThread) [zigpy_znp.uart] Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x2A\x85\x84'))
raise ValueError(
ValueError: Frame data is truncated (parsed {'Src': 0x852A, 'Status': <Status.NOT_SUPPORTED: 132>}), required parameter remains: Param(name='Routes', type=<class 'zigpy.zdo.types.Routes'>, description='Routes', optional=False)e[0m
e[31m2024-02-12 07:59:51.079 ERROR (MainThread) [aiohttp.server] Error handling request
b'\x03'
^e[0m
e[31m2024-02-12 10:20:46.059 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547708934592] Failed to send request: device did not respond
yield
return await func()
TimeoutError
result = await task
e[33m2024-02-12 12:30:10.318 WARNING (Recorder) [homeassistant.components.sensor.recorder] Entity sensor.miguelturra_rain_today from integration netatmo has state class total_increasing, but its state is not strictly increasing. Triggered by state 4.2 (4.3) with last_updated set to 2024-02-12T12:25:16.413273+00:00. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+netatmo%22e[0m
e[31m2024-02-12 17:51:06.942 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547712121792] Failed to send request: device did not respond
yield
return await func()
TimeoutError
result = await task
e[31m2024-02-12 17:59:11.459 ERROR (MainThread) [aiohttp.server] Error handling request
b'\x03'
^e[0m
e[31m2024-02-13 11:00:15.474 ERROR (MainThread) [homeassistant.components.automation.automatizacion_de_la_ventilacion] Automatización de la ventilación: Error executing script. Error for call_service at pos 1: Failed to send request: device did not responde[0m
e[31m2024-02-13 11:00:15.478 ERROR (MainThread) [homeassistant.components.automation.automatizacion_de_la_ventilacion] Error while executing automation automation.automatizacion_de_la_ventilacion: Failed to send request: device did not responde[0m
e[31m2024-02-13 16:35:26.034 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 91, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 149, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 51, in get
return await WebSocketHandler(request.app["hass"], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 284, in async_handle
await wsock.prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 152, in prepare
payload_writer = await super().prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 415, in prepare
return await self._start(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 423, in _start
await self._write_headers()
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 503, in _write_headers
await writer.write_headers(status_line, self._headers)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 130, in write_headers
self._write(buf)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 75, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transporte[0m
e[31m2024-02-13 17:18:56.952 ERROR (MainThread) [aiohttp.server] Error handling request
b'\x03'
^e[0m
s6-rc: info: service legacy-services: stopping
