1 day ago I did a clean install of HA on an sd card to use with Raspberry Pi 3.
After the installation finished, I see some issues inside the log file. Can you please advise how to fix.
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:109
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: August 26, 2021, 11:21:58 PM (1 occurrences)
Last logged: August 26, 2021, 11:21:58 PM
Failed to to call /addons/core_configurator/install - Can’t install homeassistant/aarch64-addon-configurator:5.3.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=5.3.3&fromImage=homeassistant%2Faarch64-addon-configurator: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”)
2021-08-26 00:53:21 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-08-26 00:53:23 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=2 from 2021-08-25 21:36:55.742272)
2021-08-26 00:53:40 WARNING (MainThread) [homeassistant.config_entries] Config entry ‘UPNP IGD’ for upnp integration not ready yet: None; Retrying in background
2021-08-26 23:21:58 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/core_configurator/install - Can’t install homeassistant/aarch64-addon-configurator:5.3.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=5.3.3&fromImage=homeassistant%2Faarch64-addon-configurator: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”)
2021-08-26 23:30:00 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
