Hi
I have installed HA with supervisor on a PC.
After I finised installing, HA opened no problem with Oraxle VM running.
When I shut down and tried to open up,
I got an error message Page not found.
I then open Oracle VM and HA opened up.
My question is: Have I set this up correctly? as I have to start VM first.
Or do I have to have VM start up automatically.
Any help or solution much appreciated. Thank you
How would you rate your tech skills? I’m asking, because your chosen installation is an advanced one.
A virtual machine allows you to run a “computer within a computer”, so yes, your VM must (always) be running if HA is installed within that VM.
Ok
Did you install HA Supervised on the PC, or did you install HA Supervised in a Virtualbox VM ?
OK Thank you for the reply,
My tech skills are OK…But this HA has so many options.
I chose that instaIllation because It gave me the ability to do addons.
I will do some more research for another installation option.
Do you have a dedicated system you can install it on? If so, I’ll recommend HAOS – it supports add-ons. In terms of the docs and forum question, you’ll also see that it is mostly tailored towards HAOS, so you’ll get the best support and help that way too.
Remember, add-ons are just standalone software systems, independent from HA, packaged in a nice way to work with HA.
Ok Thanks I have now installed HAOS on a decicated PC.
