Hi, I was following the guide from Alan Byrne and especially Installing Docker, Home Assistant and Portainer on Ubuntu Linux — Home Automation Guy with the difference that I’m using Qnap Container Station (Container Station | Supports LXD, Docker, and Kata Containers | QNAP) as my docker station.
I have created the docker-composer application like this:
version: '3'
services:
portainer:
container_name: portainer
image: portainer/portainer-ce:latest
restart: always
ports:
- 9001:8000
- 9000:9000
- 9043:9443
environment:
- TZ=Europe/Warsaw
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
- /opt/volumes/portainer/_data:/data:rw
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /opt/volumes/home_assistant_config/_data:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
privileged: true
network_mode: host
duplicati:
image: lscr.io/linuxserver/duplicati:latest
container_name: duplicati
environment:
- PUID=1000
- PGID=1000
- TZ=Europe/Warsaw
- CLI_ARGS= #optional
volumes:
- /opt/volumes/duplicati/_data/config:/config
- /opt/volume:/source
ports:
- 8201:8200
When I run the portainer and duplicate in the web browser directly (e.g. http://qnap.local:8201/ngax/index.html) it works fine, but when I try to add it in the HA as dashboards, I’m getting errors:
I have no idea what is causing it. Can anyone help? It looks when the page runs in the dashboard iframe, it does not have access to all ports?
