HA inaccessible after failed to call service system_log/write
I am running HA 2022.4.1 and since morning I am facing this error, “failed to call service system_log/write” after that HA becomes inaccessible, until I physically restart it.
https://www.codepile.net/pile/KryRP0An
System Health
version core-2022.4.0
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.9.9
os_name Linux
os_version 5.15.32-v8
arch aarch64
timezone Asia/Karachi
and
host_os Home Assistant OS 8.0.rc1
update_channel beta
supervisor_version supervisor-2022.04.0
docker_version 20.10.12
disk_total 29.0 GB
disk_used 25.1 GB
healthy true
supported true
board rpi4-64
supervisor_api ok
version_api ok
installed_addons Samba share (9.5.1), File editor (5.3.3), Home Assistant Google Drive Backup (0.106.2), InfluxDB (4.4.1), Grafana (7.5.2), Glances (0.15.0), ZeroTier One (0.13.2), SSH & Web Terminal (10.1.1), Check Home Assistant configuration (3.10.0), CEC Scanner (3.0), ESPHome (2022.3.1), Log Viewer (0.13.0), MariaDB (2.4.0), Tautulli (2.3.0), Webhook Relay - Remote Access (2.4.3), Tailscale (1.22.2.0), AdGuard Home (4.5.0), Samba Backup (5.0.0), ADS-B Multi-Portal Feeder (1.0.3), Angry IP Scanner (0.1.0), CUPS Print Server (1.0.0-alpha.25), Tailscale (0.6.1)
deug logs
I’m having a similar problem since upgrading to 2022.4. I’m running HASIO on a Rasberry Pi 4 (note - I only run production releases, never a release candidate). Every 2 days or so, the UI would become inaccessible until I toggle power on the RP4. The server is completely inaccessible via web browser. I can access the server via the HA IOS app, but the Dashboards don’t show up. Instead, I see a blank screen with the “settings” icon on the lower right. Sometimes, the messesge “NSURELerrorDomain -1004” would appear.
Since I automatically click update whenever a new release becomes available, I don’t know exactly which version of core or HA OS this problem started. All I know is that the problem is happening frequently with the latest release versions as of 4/10/2022 (2022.4.1; HS OS 7.6)
I face this error when accessing from browser
I get the same message in a new docker installation when I try to add an integration manually
Getting exactly the same error - failed to call service system_log.write.
Also notice Home assistant cloud item in setting says “loading…” continuously.
And CPU (Pi 4 + SSD) is running at 6% instead of a normal 3-4%.
