I have some Shelly Dimmer 2 devices added to my HA install.
I’ve also setup the InfluxDB integration in HA, to send historical data to a separate InfluxDB instance.
I’ve just enabled the power and energy sensors for my Shelly Dimmers, so that I can see those metrics in HA:
However, for some reason, these don’t seem to be sending to InfluxDB.
I see binary sensors for each Shelly, for overheating/overpowering. And I see a measurement for each Shelly Dimmer 2, with the following fields:
Does anybody know if the Energy/Power sensors in HA should be supported in the InfluxDB integration? Or is there something special you need to do to enable it?
