Hello, I would like to integrate this inverter with LSW5 WiFi dongle to HA but with no luck. Tried MQQT and integration from Stephan Joubert. I need to read the data locally not thru API from solarman. Any solution?
I have a similar inverter, same problem
hi, I also have the same problem, with afore inverter.
I can’t even get solarman API
Hello I made a custom Yaml for INVT XG110 with LSW5 wifi dongle.
I works in Stephan Jouberts integration. I sent it to him. So he can integrate it in his integration.
If you cant wait you can add the config file I wrote as a custom device
I hope it works for your Inverter
# INVT XG110 on-grid inverter
# LSW - 5 Wifi Loger with firmware LSW5BLE_17_8420_1.24
requests:
- start: 0x3806
end: 0x3859
mb_functioncode: 0x03
- start: 0x3873
end: 0x388E
parameters:
- group: solar
items:
- name: "PV01 Voltage"
class: "voltage"
state_class: "measurement"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3836]
icon: 'mdi:solar-power'
- name: "PV01 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3837]
- name: "PV02 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3838]
- name: "PV02 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3839]
- name: "PV03 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x383A]
- name: "PV03 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x383B]
- name: "PV04 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x383C]
- name: "PV04 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x383D]
- name: "PV05 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x383E]
- name: "PV05 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x383F]
- name: "PV06 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3840]
- name: "PV06 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3841]
- name: "PV07 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3842]
- name: "PV07 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3843]
- name: "PV08 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3844]
- name: "PV08 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3845]
- name: "PV09 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3846]
- name: "PV09 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3847]
- name: "PV10 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3848]
- name: "PV10 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3849]
- name: "PV11 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x384A]
- name: "PV11 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x384B]
- name: "PV12 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x384C]
- name: "PV12 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x384D]
- name: "Daily Production"
class: "energy"
state_class: "total_increasing"
uom: "kWh"
scale: 0.1
rule: 1
registers: [0x382F]
- name: "Total Production"
class: "energy"
state_class: "total"
uom: "kWh"
scale: 0.1
rule: 3
registers: [0x3831,0x3830]
- name: "Total generation time"
class: ""
uom: "s"
scale: 0.5
rule: 3
registers: [0x382E,0x382D]
icon: 'mdi:clock-outline'
- name: "Derated Power"
class: ""
uom: "W"
scale: 0.1
rule: 3
registers: [0x3829,0x382A]
icon: 'mdi:gauge'
- group: Output
items:
- name: "Output active power"
class: "power"
uom: "W"
scale: 0.1
rule: 4
registers: [0x381E,0x381D]
icon: 'mdi:home-lightning-bolt'
- name: "Output reactive power"
class: ""
uom: "Var"
scale: 0.1
rule: 4
registers: [0x3820,0x381F]
- name: "Grid frequency"
class: "frequency"
uom: "Hz"
scale: 0.01
rule: 1
registers: [0x381A]
- name: "L1 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3811]
- name: "L1 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 1
registers: [0x3817]
- name: "L2 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3812]
- name: "L2 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 1
registers: [0x3818]
- name: "L3 Voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3813]
- name: "L3 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 1
registers: [0x3819]
- name: "Leakage Current"
class: "current"
uom: "mA"
scale: 0.1
rule: 1
registers: [0x3829]
- name: "R Phase Current"
class: "current"
uom: "mA"
scale: 0.1
rule: 2
registers: [0x3832]
- name: "S Phase Current"
class: "current"
uom: "mA"
scale: 0.1
rule: 2
registers: [0x3833]
- name: "T Phase Current"
class: "current"
uom: "mA"
scale: 0.1
rule: 2
registers: [0x3834]
- name: "DC Isolation Resistance"
class: ""
uom: "kOhm"
scale: 1
rule: 1
registers: [0x3835]
- name: "String01 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x384E]
icon: 'mdi:grid'
- name: "String03 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x384F]
icon: 'mdi:grid'
- name: "String05 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3850]
icon: 'mdi:grid'
- name: "String07 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3851]
icon: 'mdi:grid'
- name: "String09 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3852]
icon: 'mdi:grid'
- name: "String11 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3853]
icon: 'mdi:grid'
- name: "String13 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3854]
icon: 'mdi:grid'
- name: "String15 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3855]
icon: 'mdi:grid'
- name: "String17 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3856]
icon: 'mdi:grid'
- name: "String19 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3857]
icon: 'mdi:grid'
- name: "String21 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3858]
icon: 'mdi:grid'
- name: "String23 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3859]
icon: 'mdi:grid'
- name: "String02 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3873]
icon: 'mdi:grid'
- name: "String04 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3874]
icon: 'mdi:grid'
- name: "String06 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3875]
icon: 'mdi:grid'
- name: "String08 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3876]
icon: 'mdi:grid'
- name: "String10 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3877]
icon: 'mdi:grid'
- name: "String12 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3878]
icon: 'mdi:grid'
- name: "String14 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x3879]
icon: 'mdi:grid'
- name: "String16 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x387A]
icon: 'mdi:grid'
- name: "String18 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x387B]
icon: 'mdi:grid'
- name: "String20 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x387C]
icon: 'mdi:grid'
- name: "String22 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x387D]
icon: 'mdi:grid'
- name: "String24 Current"
class: "current"
uom: "A"
scale: 0.01
rule: 2
registers: [0x387E]
icon: 'mdi:grid'
- group: Inverter
items:
- name: "Inverter status"
class: ""
uom: ""
scale: 1
rule: 1
registers: [0x3806]
lookup:
- key: 0
value: "Initialization"
- key: 1
value: "Stand-by"
- key: 2
value: "Normal"
- key: 3
value: "FAULT"
- key: 4
value: "Programing"
- key: 5
value: "OFF grid"
icon: 'mdi:wrench'
- name: "Inverter module R temperature"
class: "temperature"
uom: "°C"
scale: 0.1
rule: 2
registers: [0x3822]
icon: 'mdi:thermometer'
- name: "Inverter module S temperature"
uom: "°C"
scale: 0.1
rule: 2
registers: [0x3823]
- name: "Inverter module T temperature"
uom: "°C"
scale: 0.1
rule: 2
registers: [0x3824]
- name: "Inverter Heatsink temperature"
uom: "°C"
scale: 0.1
rule: 2
registers: [0x3826]
- name: "Inverter Ambient temperature"
uom: "°C"
scale: 0.1
rule: 2
registers: [0x3825]
- name: "Nbus voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x380F]
- name: "Pbus voltage"
class: "voltage"
uom: "V"
scale: 0.1
rule: 1
registers: [0x3810]
- name: "Countdown time"
class: ""
uom: "s"
scale: 1
rule: 1
registers: [0x381B]
icon: ''
- name: "Inverter efficiency"
class: ""
uom: "%"
scale: 0.1
rule: 1
registers: [0x3882]
icon: 'mdi:PercentOutline'
- name: "RTC status"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 1
registers: [0x3883]
icon: 'mdi:WebClock'
lookup:
- key: 0
value: "No RTC"
- key: 1
value: "RTC configured"
- name: "Communication quality"
class: ""
uom: "%"
scale: 0.1
rule: 1
registers: [0x3884]
icon: 'mdi:WifiStar'
- group: Alert
items:
- name: "Alarm code"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 3
registers: [0x3808,0x3807]
- name: "Alarm bit"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 3
registers: [0x380C,0x380B]
- name: "Alarm main code"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 1
registers: [0x3807]
- name: "Alarm sub code"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 1
registers: [0x3808]
- name: "Alarm"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 3
lookup:
- key: 0
value: "No error"
- key: 65537
value: "ID 01-01 FAN 1"
- key: 65538
value: "ID 01-02 FAN 2"
- key: 65539
value: "ID 01-03 FAN 3"
- key: 65540
value: "ID 01-04 FAN 4"
- key: 65541
value: "ID 01-05 FAN 5"
- key: 65542
value: "ID 01-06 FAN 6"
- key: 65543
value: "ID 01-07 FAN 7"
- key: 65544
value: "ID 01-08 FAN 8"
- key: 65545
value: "ID 01-09 FAN 9"
- key: 65546
value: "ID 01-10 FAN 10"
- key: 131073
value: "ID 02-01 Ligning Protection"
- key: 196609
value: "ID 03-01 String 1"
- key: 196610
value: "ID 03-02 String 2"
- key: 196611
value: "ID 03-03 String 3"
- key: 196612
value: "ID 03-04 String 4"
- key: 196613
value: "ID 03-05 String 5"
- key: 196614
value: "ID 03-06 String 6"
- key: 196615
value: "ID 03-07 String 7"
- key: 196616
value: "ID 03-08 String 8"
- key: 196617
value: "ID 03-09 String 9"
- key: 196618
value: "ID 03-10 String 10"
- key: 196619
value: "ID 03-11 String 11"
- key: 196620
value: "ID 03-12 String 12"
- key: 196621
value: "ID 03-13 String 13"
- key: 196622
value: "ID 03-14 String 14"
- key: 196623
value: "ID 03-15 String 15"
- key: 196624
value: "ID 03-16 String 16"
- key: 196625
value: "ID 03-17 String 17"
- key: 196626
value: "ID 03-18 String 18"
- key: 196627
value: "ID 03-19 String 19"
- key: 196628
value: "ID 03-20 String 20"
icon: 'mdi:alert'
- name: "Fault code"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 3
registers: [0x380A,0x3809]
- name: "Fault bit"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 3
registers: [0x380E,0x380D]
- name: "Fault main code"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 1
registers: [0x3809]
- name: "Fault sub code"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 1
registers: [0x380A]
- name: "Fault"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 3
lookup:
- key: 0
value: "No error"
- key: 65537
value: "ID 01-01 PV Electricity Down"
- key: 65538
value: "ID 01-02 PV Voltage High"
- key: 196609
value: "ID 03-01 BUS Voltage Low"
- key: 196610
value: "ID 03-02 BUS Voltage High"
- key: 196611
value: "ID 03-03 BUS Voltage Imbalance"
- key: 327681
value: "ID 05-01 Inverter Hardware Fault"
- key: 327682
value: "ID 05-02 Inverter Software Fault"
- key: 327683
value: "ID 05-02 Inverter BOOST Hardware Fault"
- key: 393217
value: "ID 06-01 Inverter Temperature"
- key: 393218
value: "ID 06-02 Inverter BOOST Temperature"
- key: 393219
value: "ID 06-03 Heatsink Temperature"
- key: 393220
value: "ID 06-04 Ambient Temperature"
- key: 458753
value: "ID 07-01 Insulation Fault"
- key: 524289
value: "ID 08-01 Drive Fault"
- key: 589825
value: "ID 09-01 DSP1 - ARM SCI Comm Fault"
- key: 589826
value: "ID 09-02 DSP2 - ARM SCI Comm Fault"
- key: 589827
value: "ID 09-03 DSP1 - SPI Comm Fault"
- key: 589828
value: "ID 09-04 DSP2 - SPI Comm Fault"
- key: 589828
value: "ID 09-05 SCI - MCU Comm Fault"
- key: 655361
value: "ID 10-01 Current Leakage"
- key: 655362
value: "ID 10-02 30mA Current Leakage"
- key: 655363
value: "ID 10-03 60mA Current Leakage"
- key: 655364
value: "ID 10-04 150mA Current Leakage"
- key: 720897
value: "ID 11-01 Open Circuit"
- key: 720898
value: "ID 11-02 Short Circuit"
- key: 917505
value: "ID 14-01 DCI R pfase Fault"
- key: 917506
value: "ID 14-02 DCI S pfase Fault"
- key: 917507
value: "ID 14-03 DCI T pfase Fault"
- key: 1245185
value: "ID 19-01 AC Voltage Consistency Fault"
- key: 1245186
value: "ID 19-02 BUS Voltage Consistency Fault"
- key: 1245187
value: "ID 19-03 ISO Voltage Consistency Fault"
- key: 1245188
value: "ID 19-04 PV Voltage Consistency Fault"
- key: 1245189
value: "ID 19-05 GFCI Voltage Consistency Fault"
- key: 2031617
value: "ID 31-01 Mains Voltage Low"
- key: 2031617
value: "ID 31-02 Mains Voltage High"
- key: 2162689
value: "ID 33-01 Mains Frequency Low"
- key: 2162690
- key: 2424833
value: "ID 37-01 Remote Shutdown"
- key: 2818049
value: "ID 43-01 Current Leakage sensor Fault"
- key: 2949121
value: "ID 45-01 Auxiliary Power OFF"
icon: 'mdi:alert-octagon'
- name: "Derating Mode"
class: ""
state_class: ""
uom: ""
scale: 1
rule: 1
registers: [0x382C]
lookup:
- key: 0
value: "No Derating"
- key: 1
value: "Ambient Temperature High"
- key: 2
value: "Over frequency Derating"
- key: 3
value: "Reactive Power Derating"
- key: 4
value: "User-set Active Power Derating"
- key: 5
value: "Load slope Derating"
- key: 6
value: "Fan Derating"
- key: 7
value: "Wave by Wave Derating"
- key: 8
value: "export Limit"
- key: 9
value: "Low penetration Derating"
- key: 10
value: "reset MPPT Derating"
- key: 12
value: "BUS voltage Limit"
icon: 'mdi:wrench'
This code works partially with my INVT XD6KTL inverter via DavidRapan’s SOLARMAN STICK LOGGER integration.
GitHub - davidrapan/ha-solarman: ⚡ Solarman Stick Logger integration for 🏠Home Assistant.
In a few days I will have reviewed (and modified the necessary code) to make it work 100% with my XD6KTL.
Thank you very much for the contribution!
mine is connected successfully but all sensors are not available please help me i am using INVT MG5KTL with wifi LSW3_15_8401_1.23
