HA integration ZHA not working
i can not install ZHA integration I get the error:
Rejestrator: aiohttp.server
Źródło: /usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py:448
Pierwsze zdarzenie: 19:14:13 (1 zdarzenia)
Ostatnio zalogowany: 19:14:13
Error handling request
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 477, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 559, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 83, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 81, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 172, in post
    return await self._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 179, in _post_impl
    return await super()._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 84, in _post_impl
    result = await self._flow_mgr.async_init(
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1301, in async_init
    flow, result = await self._async_init(flow_id, handler, context, data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1336, in _async_init
    result = await self._async_handle_step(flow, flow.init_step, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 517, in _async_handle_step
    result: _FlowResultT = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 535, in async_step_user
    return await self.async_step_choose_serial_port(user_input)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 177, in async_step_choose_serial_port
    ports = await list_serial_ports(self.hass)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 108, in list_serial_ports
    multipan_manager = await silabs_multiprotocol_addon.get_multiprotocol_addon_manager(
  File "/usr/src/homeassistant/homeassistant/helpers/singleton.py", line 52, in async_wrapped
    result = await func(hass)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant_hardware/silabs_multiprotocol_addon.py", line 71, in get_multiprotocol_addon_manager
    manager = MultiprotocolAddonManager(hass)
  File "/usr/src/homeassistant/homeassistant/components/homeassistant_hardware/silabs_multiprotocol_addon.py", line 128, in __init__
    super().__init__(
  File "/usr/src/homeassistant/homeassistant/components/hassio/addon_manager.py", line 112, in __init__
    self._supervisor_client = get_supervisor_client(hass)
  File "/usr/src/homeassistant/homeassistant/helpers/singleton.py", line 42, in wrapped
    hass.data[data_key] = func(hass)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 383, in get_supervisor_client
    hassio: HassIO = hass.data[DOMAIN]
KeyError: 'hassio'
Im running HA on docker container image: homeassistant/home-assistant:latest.
In general what I aim, is to install Sonoff ZBDongle-E.
I will reply my own post.
My full setup was Synology NAS DSM 7.2 + docker HA + Zigbee Dongle :slight_smile:
So the issue was the host drive to handle USB properly.
So I followed the steps here: https://giuliomenna.net/blog/synology-nas-usb-port-activation-for-sonoff-zigbee-dongle-and-zigbee2mqtt/
In my case the outcome was not /dev/ttyUSB0 but /dev/ttyACM0
I also created a docker compose file to have more control over container:
version: '3.4'
services:
  home-assistant:
    container_name: home-assistant
    image: homeassistant/home-assistant:beta
    devices:
      - /dev/ttyACM0:/dev/ttyUSB0
    volumes:
      - /volume1/docker/homeassistant/config:/config
    network_mode: host
And now the Zigbee Home Automation was automaticaly detected.
