HA IOS App unable to connect to new HA Green
Brand new Home Assistant Green, when opening the HA iOS app on iPhone 13 running 17.6.1 I see an available server for connection:
http://192.168.4.146:8123
I click on that, and eventually it times out giving the error:
Failed to Connect
The request timed out.
Error Code:
NSURELErrorDomain -1001
Am able to successfully connect from a browser on a Windows computer using Chrome by going to:
http://homeassistant.local:8123/
Through the iPhone app I can export log files and I can see the following error message:
2024-10-03 21:01:08.949 [Verbose] [main] [Realm+Initialization.swift:95] getRealm(objectTypes:) > Current schema version 28
2024-10-03 21:01:08.949 [Verbose] [main] [Realm+Initialization.swift:100] getRealm(objectTypes:) > Schema version defined: 28
2024-10-03 21:01:41.403 [Verbose] [main] [OnboardingManualURLViewController.swift:144] connectTapped(_:) > Connect button tapped
2024-10-03 21:01:41.411 [Info] [main] [OnboardingAuth.swift:80] performPreSteps(checkPoint:authDetails:sender:) > beforeAuth
2024-10-03 21:01:41.411 [Verbose] [main] [OnboardingAuthStepConnectivity.swift:25] perform(point:) >
2024-10-03 21:02:41.859 [Info] [main] [OnboardingAuth.swift:70] perform(checkPoint:checks:) > OnboardingAuthStepConnectivity: rejected(HomeAssistant.OnboardingAuthError(kind: HomeAssistant.OnboardingAuthError.ErrorKind.other(Error Domain=NSURLErrorDomain Code=-1001 "The request timed out." UserInfo={_kCFStreamErrorCodeKey=-2102, NSUnderlyingError=0x300b35b00 {Error Domain=kCFErrorDomainCFNetwork Code=-1001 "(null)" UserInfo={_kCFStreamErrorCodeKey=-2102, _kCFStreamErrorDomainKey=4}}, _NSURLErrorFailingURLSessionTaskErrorKey=LocalDataTask <73BBA399-DC3A-4A00-A824-123EABCAC51B>.<1>, _NSURLErrorRelatedURLSessionTaskErrorKey=(
    "LocalDataTask <73BBA399-DC3A-4A00-A824-123EABCAC51B>.<1>"
), NSLocalizedDescription=The request timed out., NSErrorFailingURLStringKey=http://homeassistant.local:8123/lovelace/0/auth/authorize?response_type=code&client_id=https://home-assistant.io/iOS&redirect_uri=homeassistant://auth-callback, NSErrorFailingURLKey=http://homeassistant.local:8123/lovelace/0/auth/authorize?response_type=code&client_id=https://home-assistant.io/iOS&redirect_uri=homeassistant://auth-callback, _kCFStreamErrorDomainKey=4}), data: nil))
2024-10-03 21:06:00.523 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason periodic
2024-10-03 21:07:03.476 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason warm
2024-10-03 21:09:24.560 [Info] [main] [PeriodicUpdateManager.swift:57] connectAPI(reason:) > Connect finished for reason warm
Any suggestions on what to attemp to get the iPhone companion app working?
Try to set internal and external url in the server settings to the ip address of the HA server, this worked for me.
Thanks for the reply!
Sadly, did not work for me.
Notes for anyone following:
internal and external url were not immediately available on Home Assistant Green. First needed to turn on Advanced mode by clicking on username in the lower left. Then add a file Editor, click on the FIle Editor in the toolbar on the left, click on the folder in the upper left and choose to edit configuration.yaml
Add the following:
homeassistant:
  external_url: "http://<ip_address>:8123"
  internal_url: "http://<ip_address>:8123"
You can restart by going to:
Settings > System
And in the upper right is a power button icon that lets you restart.
Now you can edit external and internal URL by going to
Settings > System > Network > Home Assistant URL
I set up a Nabu Casa account and enabled the cloud. If I manually enter the Nabu Casa URL into the app, I can get a login page to appear.
I can’t log in as it always says the password is wrong. This is repeatable on the computer browser as well, but now I assume that’s an issue for a different thread.
TL;DR: It started working, I don’t know why, but I think it has to do with the phone IP address
I was having problems signing in to a different app (ChargePoint for EV charging). I could login using the website, but not the phone (similar symptoms to the HomeAssistant app). Their IT department said that the IP address my device was being blocked due to the IP being owned by a cloud hosting provider “tzulo” which previously exhibited fraudulent behavior on their network. In the past, they had seen this happen when using “Mullvad VPN” or when iCloud Private Relay was enabled on the phone (iCloud Private Relay is automatically enabled with an iCloud+ or Apple One subscription). In response, I verified that I do indeed have iCloud Apple Relay turned on, so I turned it off and then back on again, and played around with some VPN settings. I ended up in the same place I was at to begin with, but the ChargePoint app started working. A little while later, on a whim, I tested the HomeAssistant app and it also started working.
Knowing what my ISP, router, or Apple is doing with my traffic is a little beyond my expertise, but my phone seems to have healed.
