So after doing some clean up in my scripts (moving things around, not changing anything) I restarted my HA (Hass.io) and the notifications stopped working with the following error message:
Log Details (ERROR)
Fri May 11 2018 22:27:36 GMT+1000 (AEST)
Error executing service <ServiceCall notify.ios_hasspad: message=<homeassistant.helpers.template.Template object at 0x72cb5af0>>
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 850, in _validate_conn
conn.connect()
File "/usr/lib/python3.6/site-packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/usr/lib/python3.6/site-packages/urllib3/util/ssl_.py", line 329, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.6/ssl.py", line 407, in wrap_socket
_context=self, _session=session)
File "/usr/lib/python3.6/ssl.py", line 814, in __init__
self.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 1068, in do_handshake
self._sslobj.do_handshake()
File "/usr/lib/python3.6/ssl.py", line 689, in do_handshake
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by SSLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)'),))
File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1002, in _event_to_service_call
await service_handler.func(service_call)
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 137, in async_notify_message
yield from notify_service.async_send_message(**kwargs)
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/notify/ios.py", line 94, in send_message
req = requests.post(PUSH_URL, json=data, timeout=10)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 112, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 506, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by SSLError(SSLError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:777)'),))
As far as I can tell, my SSL certificate works fine, and there are no other issues reported.
I should add I’m on 68.1 and have been for a few days, haven’t had any issues with this till now. Also tried to notify 2 other iOS devices with the same error message.
Any ideas?
