HA is constantly crashing and restarting and i'm out of ideas. Can anyone help?
Hi, I’ve had HAOS running prefectly for past 18 months on a RasberryPi. At the weekend I updated to latest OS and switched from ZHA to ZigBee2MQTT. All was fine for a day and now the system is constantly crashing and re-starting, over and over. I’m struggling to even download logs as it crashes each time i try… Any ideas on what I should try next? Thanks a lot.
Connect a screen to see what happens.
Thanks, working my way through the list!
You also did not tell us what version Pi and how much ram or what storage it has?
Sorry about that:
host_os | Home Assistant OS 13.2
update_channel | stable
supervisor_version | supervisor-2024.11.2
agent_version | 1.6.0
docker_version | 27.2.0
disk_total | 57.8 GB
disk_used | 5.7 GB
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization |
board | rpi3-64
supervisor_api | failed to load: timeout
version_api | failed to load: timeout
installed_addons | Terminal & SSH (9.6.1), File editor (5.8.0), Studio Code Server (5.5.6), Mosquitto broker (6.4.1), Zigbee2MQTT (1.41.0-1), Get HACS (1.3.1)
I don’t know any Pi3 that shipped with 64g.so I assume that’s storage? How much RAM does it have?
Pi3 is the ABSOLUTE bare minimum for current system requirements and honestly 1GB of RAM (default max configuration for a pi3 if memory serves) is barely adequate if you have any complexity to your install whatsoever. In addition to the steps on the troubleshooting list I’d add - did I just run out of RAM and crash the box) to your most likely list.
Thanks Nathan - It’s a Pi3 model B with 1GB RAM, so that could be the problem! Time to upgrade i think as I have quite a large config…
