I’m using a rpi3 with sd card. I know. This will fail after some time. I have this problem. Home assistant is still booting and telling me in the screen. ipv4 addresses for eth0 : 192.168.1.120/24. Home assistant URL: http://homeassistant.local:8123.
I set 192.168.1.120 as a fixed ip address in my router.
I use netscan on my windows pc and 192.168.1.120 is not visible in netscan. Ping requests fail. App also doesn’t work.
How can I see what is wrong? I can connect a keyboard and monitor to the rpi3. How can I restore the Ethernet connection and web interface? Perhaps enabling the wifi would also be an option. Enabling from command line.
How can I make a command line backup and write it to USB disk?
Best regards,
Erik
