Get 2 mayor errors…
Unexpected error fetching homewizard data: Resource not found
2024-01-11 09:43:13.389 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-01-11 09:43:13.409 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=1297 from 2024-01-11 08:31:25.710748)
2024-01-11 09:43:26.837 ERROR (SyncWorker_4) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to 'HTTPConnectionPool(host='a0d7b954-influxdb', port=8086): Max retries exceeded with url: /write?db=homeassistant (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f90496da910>: Failed to establish a new connection: [Errno 111] Connection refused'))'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
2024-01-11 09:43:27.025 ERROR (MainThread) [homeassistant.components.homewizard.coordinator] Unexpected error fetching homewizard data: Resource not found
What can I do about it ?
